Sam,Can you tighten the pliers mount screws anymore than they are(I know some SOG models have pins that are bottomed out)? That is how I got mine to stop opening in my pocket.
But I like to flik the pliers open and bash my knuckles a little..
That's alot of improvements from the original design RC! I would really like to incorporate some kind of swing lock for the handles.. The pocket clip is on the wrong end and the handles keeps opening up in my pocket..
Something like the Kershaw A100's would work, maybe on the other side of where the Pint's pocket-clip is.put a latch on one screw, and have a narrow washer to lift the screw's head, so the latch can hook it.
This sounds like a good idea ReamerPunch! All we need is to source a suitable latch that will fit, if not it has to be custom-made?Gosh, I wish SOG is listening !
I think it would be easy to fabricate from some mild hardness thinner gauge steel. Using a dremel and assorted cutting wheels and bits. And a lot of patience.
Thanks for the tip! Has anyone disassembled the torx screws, took out the implements and put it all back together in their Pint yet? How easy/difficult is it to put the tension springs back together?
Anytime! Should be a fun project. It is one of the easier tools to break down and put back together(relatively of course). The only issue I would mark as somewhat serious is the thin washers. Make sure they do back between the correct implements. The newer versions have better quality washers, but if you have an early Pint, they will be thin and flimsy. Just something to watch for.
Cool hack, roamingcat!
A couple of questions though, if you don't mind?! Do you ever lose the clips? And how long does a nice one take to make?
Sure, not at all. I haven't lost a clip yet, but it is mainly because I only had it for less than 24 hours and I haven't been carrying it around too much I agree with you it may be prone to loosing since there is no permanent attachment to the Pint. fyi I made the first u-clip in about a minute, and if I ever loose it I can re-make a replacement in less than a minute since I am already familiar with the overall shape. All that is required is a paper clip, 2 cuts + 2 bends (with one finger and one set of pliers) btw - I have further 'refined' the u-clip in the attached photo. It has worked well for me so far (within the last 24 hous or so).
I want to love this tool so badly... perfect size, good tool selection (short of flat head drivers)... but the small flathead that is onboard bends at will and is seemingly made of pot metal... the scissors leave a lot to be desired as well... I am in love with the design, just wish it was executed better!
The last SOG MT I bought, and I don't even remember the name [it was the PowerAccess], was so poorly made that I dropped out of an MTO Challenge and returned the thing to Amazon. The "file" was as smooth as a baby's rump, and the whole thing was just flimsy and cheap.
