So close to being perfect
Offline 386greene
on: May 09, 2018, 10:10:41 PM
I wish these worked like this, the juice would become my daily carry.
Too bad I guess.. unless anyone's got any ideas?
* IMG_20180509_155920_1.jpg (Filesize: 271.1 KB)
00 Offline Sam Lim
Re: So close to being perfect
Reply #1 on: May 10, 2018, 01:47:15 AM
Would it help if u put the pliers on the other end? Looks like the blade and scissors are hitting each other. The other end should give u more clearance.
But then again, is the back spring's size/width compatible?
« Last Edit: May 10, 2018, 01:50:21 AM by Sam Lim »
us Offline Obi1shinobee
Reply #2 on: May 10, 2018, 02:57:23 AM
 :dd:
Reply #3 on: May 10, 2018, 03:00:11 AM
 :multi:
* ReBlaster X OHO (1).png (Filesize: 110.85 KB)
Reply #4 on: May 10, 2018, 04:39:24 AM
Sam know his stuff :salute: I hope you get this figured out :cheers: Good luck :salute:
00 Offline Sam Lim
Reply #5 on: May 10, 2018, 12:35:10 PM
I was very lucky to find matching parts and have a very bad habit of breaking apart stuffs.. I happen to have a loose squirt plier head. (see..  :facepalm:) but unfortunately like in your pic. Doesn't quite match up.. Spring thickness will be another problem also.. But thats why modding is fun eh..  ;)
 :popcorn:
Reply #6 on: May 10, 2018, 03:42:07 PM
 :popcorn:
 :dd:   Help Me Obi1shinobee your my only Hope !  :ahhh :ahhh :ahhh :ahhh :rofl: :rofl: :rofl:
00 Offline Sam Lim
Reply #7 on: May 10, 2018, 04:58:59 PM
 :popcorn:
 :popcorn: :popcorn: :popcorn:
BTW Greene, looking at the pliers, I think it's a better idea to loose the spring and use the top hole for the pivot. That should give u more material to work with. Actually I think this should work.
* IMG_20180510_225255-684x912.jpg (Filesize: 133.18 KB)
Offline 386greene
Reply #8 on: May 11, 2018, 10:35:07 PM
I was thinking that exact thing, let me try swapping ends to get some clearance with the scissors and all, then I'll try them that way. When I get some time to sit down with it lol
The springs aren't perfect but it does snap open and closed
