Login
Register
Menu
Home
Help
Forum
Tool Talk
Leatherman Tools
Charge ALX somehow loose on one handel in closed position
Raoul Octav
9 ·
746
« previous
next »
Print
Pages:
1
Go Down
Raoul Octav
Sr. Member
416
on:
May 18, 2018, 09:39:33 AM
Hello, i need your expertise.
I have a charge ALX, wich, in closed position does not stay closed. One handel is loose and rattles for 4 mm measured at the bottom.
I believe that the V shaped inside handels spring is to blame. How can o torque it so my tool stays fermly closed?
Many thx
Sanger's laws:
-any problem has more than one resolve!
-by the way you look at the problem, the resolve may change!
-where's a will there's a way !
Raoul Octav
Sr. Member
416
Re: Charge ALX somehow loose on one handel in closed position
Reply #1 on:
May 18, 2018, 09:48:38 AM
pics
(Filesize: 40.79 KB)
(Filesize: 97.39 KB)
(Filesize: 95.69 KB)
Last Edit: May 18, 2018, 09:51:27 AM by Raoul Octav
Sanger's laws:
hiraethus
Admin Team
Absolutely No Life Club
6,965
I brake for cake
Reply #2 on:
May 18, 2018, 09:54:02 AM
Looks brand new - is it possible to send it back to Leatherman?
The little spring inside the handles doesn't do much to change the handle stiffness. It's probably the pivot that's loose. Is there any play in the blades on that side?
Also, are there any washers between the pliers and handle?
Last Edit: May 18, 2018, 09:55:24 AM by hiraethus
Merit Badges
Raoul Octav
Sr. Member
416
Reply #3 on:
May 18, 2018, 10:43:02 AM
Brand new, washers everything is ok.Blades open and clsoes ok. No play at pliers pivot.
I would want no warranty at this point
Sanger's laws:
Fuzzbucket
9,585
Reply #4 on:
May 18, 2018, 11:22:03 AM
I agree with Hirohito, sounds like the pivot to me.
Merit Badges
Mechanickal
Zombie Apprentice
14,686
Reply #5 on:
May 18, 2018, 11:27:43 AM
The V-shape only activates the bladelock when opening the pliers.
They have nothing to do with tensioning the pivot point.
Merit Badges
chrono
No Life Club
1,313
Find me if you can...
Reply #6 on:
May 18, 2018, 01:40:52 PM
Perhaps the spacing inside the frame is slightly too wide, thus not enough friction to keep the handles closed?
Merit Badges
SteveC
Global Moderator
Just Bananas
67,645
Reply #7 on:
May 18, 2018, 01:44:13 PM
Sounds like a loose plier pivot.
Merit Badges
Raoul Octav
Sr. Member
416
Reply #8 on:
May 24, 2018, 08:06:56 PM
I managed to get a Surge gen1 with the same issue, and i have to admit i was wrong regarding the inner v spring.
After reassembly i tightened the bolt at the handles and pliers and removed the play uet at the cost of having the outside tools extremely hard to open.
CHRONO's statement is the most accurate in such cases... the spacing inside the frame is slightly too wide, thus not enough friction to keep the handles closed.
Sanger's laws:
Print
Pages:
1
Go Up
Forum
Tool Talk
Leatherman Tools
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$168.99
PayPal Fees:
$9.87
Net Balance:
$159.12
Below Goal:
$140.88
Site Currency:
USD
53%
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
