Victorinox toothpick question
be Offline Milan Vandenbilcke
on: June 21, 2018, 05:32:21 PM
What kind of plastic is the victorinox toothpick, and could I glue it?
Verstuurd vanaf mijn XT1685 met Tapatalk
22 year old tinkerer
pt Online pfrsantos
Re: Victorinox toothpick question
Reply #1 on: June 21, 2018, 05:34:38 PM
I don't know and probably yes (depending on the type of glue).
 :think: :think:
pt Online pfrsantos
Reply #2 on: June 21, 2018, 05:36:45 PM
Why the question? You broke one and want to glue it together? Better to get a new one... It's not very stiff, probably glueing it won't work for long (if at awl).
 :think: :think:
Reply #3 on: June 21, 2018, 05:43:19 PM
The toothpick is not expensive to replace
And most shops that sell SAKs have replacements
Or the internet is a good place to get toothpicks cheap  :tu:
gb Offline BePrepared
Reply #4 on: June 21, 2018, 06:20:12 PM
I cut down and did a bit of whittling/carving of a wooden cocktail stick to make a replacement --- I wasn't very good, but I want to try again because I think I could make a few and then dispose of the used toothpicks after use.
Reply #5 on: June 21, 2018, 06:43:07 PM
Because I'm using it in my leatherman and want to make a clean 'nailnick' so was going to glue an new endpiece on it.
Reply #6 on: June 22, 2018, 09:13:55 AM
pt Online pfrsantos
Reply #7 on: June 22, 2018, 01:34:29 PM
no Offline Vidar
Reply #9 on: June 22, 2018, 02:20:36 PM
Just give it a go? Worst case you have to get a new toothpick.
Most plastics will glue just fine, and some Superglues from say Loctite will also do the difficult plastics like Polyethylene. (That is actually a likely candidate for the tooth pick material if I were to guess).
You might want to check that the glue for tooth pick isn't a crazy health danger and that it can withstand moisture?
Edit: Another option might be to use heat and weld something onto it.
« Last Edit: June 22, 2018, 02:22:54 PM by Vidar »
"Simple is hard"
"Hard is hard too"
no Offline Vidar
Reply #10 on: June 22, 2018, 02:28:58 PM
Looking at one of those toothpicks it is marked with the letter "7". I assume that is the ISO recycling code for plastic type. 7 is the bin for "other", so I guess none of the usual plastic suspects then.
« Last Edit: June 22, 2018, 02:30:07 PM by Vidar »
"Simple is hard"
"Hard is hard too"
Reply #11 on: June 22, 2018, 02:36:18 PM
Front side of the toothpick? Near the head?
I just checked mine. 3, 8, 30, 34. Different numbers!
« Last Edit: June 22, 2018, 02:38:03 PM by Don Pablo »
no Offline Vidar
Reply #12 on: June 22, 2018, 03:08:38 PM
I guess not a recycling code then. Ok, back to polyethylene as my prime suspect and just give it a try :)
"Simple is hard"
"Hard is hard too"
Offline george1
Reply #13 on: June 23, 2018, 01:05:09 PM
Polyethylene has a density below 1g/cm3 so will float.
l just tried one of my toothpicks and it sunk, so l'm going to say that they aren't PE.
This is probably a good thing as PE requires special 2 part glues. l've done it once for work and the glue had a special mixing nozzle.
Another way to determine the type of plastic is to burn it and see what colour the flame is, does it drip etc.
lf anyone has a broken toothpick...
Reply #14 on: June 23, 2018, 01:18:03 PM
I kinda forgot to answer, but the toothpick glues just fine. See the pics.
Reply #15 on: June 23, 2018, 01:32:25 PM
Excellent job looking good  :tu: :like: :like:
pt Online pfrsantos
Reply #16 on: June 26, 2018, 05:46:36 PM
+1
Very kewl idea! Looks like a standard tool.
 :tu: :tu:
Reply #17 on: February 07, 2021, 01:10:17 PM
A bump for more views for this very cool idea and execution. :tu:
Reply #18 on: February 07, 2021, 01:31:13 PM
pt Online pfrsantos
Reply #19 on: February 09, 2021, 03:17:39 PM
