Camera Adapter for Leatherman
us Offline Outback in Idaho
on: July 11, 2018, 07:40:35 AM
Am looking for ideas on adding a screw-type camera camera adapter for a Leatherman, as it seems I'm always forgetting to bring a tripod, when out in the field. Figured perhaps others might have some ideas on how to fabricate such an item/adapter that can be used with most any Leatherman multi-tool - perhaps attaching to the large bit driver. or through the pliers area when the tool is spread out.
Have a Sony Cyber-shot camera, and a GoPro Hero Session (squared type). Have a GoPro adapter o the end of a selfie stick but this doesn't work well as a tripod/bipod/holder.
¬ Outback in Idaho
00 Offline Dutch_Tooler
Re: Camera Adapter for Leatherman
Reply #1 on: July 11, 2018, 08:52:40 AM
Something like this? Imagine a spread out LM for two of the tripod legs and the clamp turn knob for the third. Clamped on the plier pivot.
Cheers!
Dutch_Tooler
nz Offline Syncop8r
Reply #2 on: July 14, 2018, 02:12:53 AM
I picked one of these up cheap a couple of years ago:
I can see how you might want to use the legs of a MT... still need a third leg though. Plus if you want the gimbal assembly as well as the screw it starts getting bulky...
us Offline gerleatherberman
Reply #3 on: July 14, 2018, 05:59:58 AM
Maybe check out the Gerber Steady MT and see if anything about it could be adapted/inspired to a LM tool?
Reply #4 on: July 30, 2018, 12:36:19 PM
Found the Joby magnetic-footed Gorillapod tripod where the joints kept falling apart or loosened up far too much. Cheap plastic stuff. :twak:
So... stub-ified it.
Using a Smurf'in Flair for more stability  :D
Essentially one could find a threaded bolt to fit cameras, one with a wider base. The attach a magnet to the underside, and should fit any multitool or other metal object. Since am looking for portability a rare earth magnet would work. Shunt a plate of metal across it to keep that magnet under control when not in use.
« Last Edit: July 30, 2018, 12:39:26 PM by Outback in Idaho »
¬ Outback in Idaho
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
