Gerber Suspension NXT & Truss by The Meaurements
us Offline gerleatherberman
on: July 31, 2018, 11:18:37 PM
Gerber Suspension NXT & Truss By The Measurements.
I have read a lot of differing opinions and assertions related to the new Gerber Truss and Suspension NXT. Some of which I could not verify just by looking at the tools and fiddling with them. I do have mid-large hands, so even the Truss doesn't feel all that big. I can, however, see how it would be too big for normal sized hands. :ahhh
I brought out the Original Suspension and Bear Grylls Survival Multi Tool(Suspension with thicker handles). All tools have the same plier head. This thread shows the measurements, to the most exact level I can possibly take with my tools, within reason. Please see the Gerber website links for full tool descriptions and prices.
The Suspension NXT and Truss are not as comfortable as the original Suspension and Bear Grylls Tools, because of the thinner handle steel. IMO, not a huge deal, because these are medium duty tools. The payoff on the handle steel being thinner is a dramatically reduced weight for the new tools from Gerber. :)
The Specimens
The Suspension NXT has 7 handle implements(15 tools).
https://www.gerbergear.com/Multi-Tools/Butterfly-Opening/Suspension-NXT_30-001364
The Truss has 9 handle implements(17 tools).
https://www.gerbergear.com/Multi-Tools/Butterfly-Opening/Truss_30-001343
The Original Suspension has 9 handle implements(15 tools).
https://www.gerbergear.com/Multi-Tools/Butterfly-Opening/Suspension-Multi-plier_22-41471
The Bear Grylls Survival Tool has 9 handle implements(15 tools).
https://www.gerbergear.com/Multi-Tools/Butterfly-Opening/Survival-Series-Ultimate-Multi-Tool_31-000749
The accurate measurements:
Closed Length:
Suspension NXT(new) – 104.9mm(4.13”)
Truss(new model) – 106.4mm(4.19”)
Suspension(original) – 98.7mm(3.88”)
BG Survival Tool – 98.7mm(3.88”)
Closed Width(at widest point):
Suspension NXT(new) – 42.4mm(1.67”)
Truss(new model) – 48.2mm(1.89”)
Suspension(original) – 47.6mm(1.87”)
BG Survival Tool – 47.4mm(1.86”)
Handle Thickness(not including screw heads or unlocking slides):
Suspension NXT(new) – 14.4mm(0.56”)
Truss(new model) – 17.1mm(0.67”)
Suspension(original) – 18.5mm(0.73”)
BG Survival Tool – 19.3mm(0.76”)
Handle Steel Thickness:
Suspension NXT(new) – 1.2mm(0.05”)
Truss(new model) – 1.1mm(0.04”)
Suspension(original) – 1.8mm(0.07”)
BG Survival Tool – 2.2mm(0.08”)
Handle Splay When Opened(at widest point):
Suspension NXT(new) – 73.7mm(2.90”)
Truss(new model) – 65.9mm(2.59”)
Suspension(original) – 65.5mm(2.58”)
BG Survival Tool – 67.1mm(2.64”)
Weight(tool only):
Suspension NXT(new) – 6.920oz(196.0g)
Truss(new model) – 8.345oz(236.6g)
Suspension(original) – 9.008oz(255.4g)
BG Survival Tool – 9.460oz(268.2g)
I hope this thread can help anyone who was curious about the sizes of all of these tools. :cheers:
Here are a few side-by-side-by-side-by-side pictures.
1) Tools laid flat on table.
2)Tools on their sides - Phillips driver sides.
3)Tools on their sides - Alternate side.
us Offline NetsNJ
Re: Gerber Suspension NXT & Truss by The Meaurements
Reply #1 on: July 31, 2018, 11:42:22 PM
Quote
Wow.  It feels like a much bigger difference.
Nice thread GLBM!   :tu:
Reply #2 on: July 31, 2018, 11:52:06 PM
Quote
Thank you, NetsNJ! :cheers:
To be honest(I thought the same thing you did), I thought the difference was going to be at least .2-.3mm, judging by eye. I measured every corner to make sure the measurements were consistent. I think the NXT is better finished on the edges, and that gives the impression that it has thicker steel.  :ahhh
Oh, and I do like the NXT! You and Sam were right. The tool load-out and smaller size are pretty awesome. And that pocket clip. Wow. Finally a reasonably long clip on a multi-tool! :)
us Offline NetsNJ
Reply #3 on: August 01, 2018, 01:57:38 AM
Is the measurement in inches or mm the more accurate one?  One implies a 20% difference, the other an 8% difference.  I assume this is from rounding?
Reply #4 on: August 01, 2018, 02:36:01 AM
Indeed, it is from automatic rounding of the inch setting to just 1/100th of an inch. The caliper I used isn't great, but it does work. The millimeter measurements are the best for that particular caliper.
I'll get out my fancy pants caliper and post more accurate(1/1000th) measurements in a minute.  :tu:
Reply #5 on: August 01, 2018, 02:51:35 AM
Further accurate handle steel thickness results:
NXT - 1.24mm (0.0495")
Truss - 1.14mm (0.0450")
Suspension - 1.84mm (0.0725")
BG Survival - 2.23mm (0.0875")
The 10,000th is rounded to either 0 or 5 by the caliper.
I can't do any better than that, NetsNJ. :ahhh
Edit: typo.
« Last Edit: August 01, 2018, 02:53:05 AM by gerleatherberman »
us Offline NetsNJ
Reply #6 on: August 01, 2018, 05:05:00 AM
Hahahaha.  Thanks
00 Offline Sam Lim
Reply #7 on: August 01, 2018, 08:12:57 AM
Edit: typo.
 :D anything better than the eyeball gauge is better..  :rofl:
Glade u like the NXT!
Reply #8 on: August 01, 2018, 02:41:52 PM
Thank you, Sam! :cheers:
The only thing about it I don't like about it, is what MetsNJ noted(I think it was him. May be you?). The blade rubs on the pliers head. But, I can't see that being  a deal breaker. There is a lot to like about it  :)
March Goal: $300.00
Due Date: Mar 31
Total Receipts: $177.50
PayPal Fees: $10.27
Net Balance: $167.23
Below Goal: $132.77
56%
March Donations
