I tried really hard to like the Compact as an EDC, honest.....But for me, and for the functions that important for me to justify carrying a sak it just falls short im afraid....Apart from a small knife blade i must have some reliable drivers, pry bar and the like with me. It's every bit as important as the cutting tasks. The combo tool is good if you just need to use it for its intended use, but for a pry bar, screw driver that can handle medium torque, scraper, etc, it just doesn't work for me. I can do 90% of what scissors do with the blades, just not as easily, but that doesn't bother me, and i can always use the ones on my key chain classic.If it had the Phillips instead of the corkscrew at least it would have a light/ medium torque SD. The plus scales only add a pen, while handy not of huge value to me. If i really only wanted the same functionality of the compact, id rather carry the Executive, much smaller and thinner
Compact for EDC? Why not. I always carry the Compact as a partner for my Spirit. (Image removed from quote.)Sent from my A37f using Tapatalk
Concerning the choice of an EDC, I think it really comes down to requirements and preferences--what do I need and what do I want?
WITH keyring!!You just file off yours.I can't add one
Quote from: Mechanickal on August 05, 2018, 03:40:35 PMWITH keyring!!You just file off yours.I can't add one LOL Fair enough mate... But it's just i'm a bit tired of grinding that ring tab off, the Dremel always slips and graze a scale or a liner, and the metal shavings always get on the springs no matter how well you tape off the area. It's a pain to wash it all out of there and re-lube everything...
The combo tool is going to take some getting used to. Using the standard cap lifter tool is reflexive at this point, and the combo tool is different enough to seem to work less intuitively. The key ring attachment is probably going to have to go, noticible digging in my palm. The key ring mount on other 91mm models where it's part of the back spring is more comfortable.
Quote from: classicrock on August 05, 2018, 10:06:44 AMCompact for EDC? Why not. I always carry the Compact as a partner for my Spirit. (Image removed from quote.)Sent from my A37f using Tapatalkwhat a pic!!
Quote from: AZ_Hiker on August 07, 2018, 08:49:21 AMThe combo tool is going to take some getting used to. Using the standard cap lifter tool is reflexive at this point, and the combo tool is different enough to seem to work less intuitively. The key ring attachment is probably going to have to go, noticible digging in my palm. The key ring mount on other 91mm models where it's part of the back spring is more comfortable.Still way-way better than on the 93 mm models. Those really dig into your palm.
Quote from: Exeter on August 07, 2018, 12:02:21 PMQuote from: AZ_Hiker on August 07, 2018, 08:49:21 AMThe combo tool is going to take some getting used to. Using the standard cap lifter tool is reflexive at this point, and the combo tool is different enough to seem to work less intuitively. The key ring attachment is probably going to have to go, noticible digging in my palm. The key ring mount on other 91mm models where it's part of the back spring is more comfortable.Still way-way better than on the 93 mm models. Those really dig into your palm.Yep, my Farmer and Pioneer that I occasionally carry both had the keyring mount immediately removed when I got them. I have to say, that something I like about my Leatherman tools is that they pretty much all have a fold out keyring/lanyard mount that can be deployed or stowed as needed.
Of course every SAK is a trade off. That´s why I have so many different ones.
I went ahead and filed off the keying mount, much better in the pocket and the hand now. Still getting used to the combo tool. I've used it to open cans, tighten screws and as a cap lifter. It does seem to be a compromise versus the standard opener layer, not quite as good at things as the two tools it replaces. No real surprise there, but not really bothersome so far.
I used to be awl about the combo tool but now I'm awl about the standard openers and awl
