Fire Damage
gb Offline fred2892
Fire Damage
on: August 15, 2018, 12:11:44 PM
Recently had a house fire. Here’s a couple of SAKs that suffered.
Is it likely the properties of the blades have been altered enough by the heat to have affected them?
us Offline dkop1
  • Acknowledged blade-aholic who isn't seeking help.
Re: Fire Damage
Reply #1 on: August 15, 2018, 12:17:00 PM
If the scales didn't completely cook away, there's a chance that it didn't get hot enough at the blade steel to ruin their original temper. Still, sorry for your loss of SAKs and damage to your home  :( I hope you and your family/housemates/pets/whomever are otherwise well!
"Have yourself a nice long rest and be back here in twelve minutes."
"All the good times, that's what I'll remember. I think there were three."
gb Offline fred2892
Fire Damage
Reply #2 on: August 15, 2018, 12:33:29 PM
Thanks, nobody was hurt and Boris the tortoise survived so it’s just a waiting game for the rebuild right now.
I am a complete amateur when it comes to SAKs and have only just joined the forum so please excuse any errors I make.
Is there a sticky or webpage anywhere so I can identify what models these were as it sounds so lame referring to “the small one”.
So anyway, I cleaned up the small one and fitted some new scales and it functions as it used to. I’m presuming if it was affected, it would have softened and not hardened any metal.
As you can see it is in ‘loved’ condition as it was my most used out of all my pocket knives. It also has the corkscrew, but the small corkscrew driver hasn’t been replaced yet.
« Last Edit: August 15, 2018, 12:52:53 PM by fred2892 »
us Offline VICMAN
Re: Fire Damage
Reply #3 on: August 15, 2018, 12:56:18 PM
Welcome to the forum fred!  :cheers:
Glad no one was hurt.
That small one cleaned up great. :tu: :tu:
Here is the URL for Sakwiki for information on Swiss Army Knives
http://www.sakwiki.com/tiki-index.php
gb Offline fred2892
Fire Damage
Reply #4 on: August 15, 2018, 01:26:26 PM
Thanks for the link, can’t find exact model but it is the same as 91mm compact but without the hook.
The second knife in the original pic is a 111mm Adventurer. It was gifted to me as a Danish Army issue knife, but I am sceptical of this as it had no military markings and I can’t find reference to Danish issue SAKs.
« Last Edit: August 15, 2018, 01:37:54 PM by fred2892 »
Re: Fire Damage
Reply #5 on: August 15, 2018, 01:40:18 PM
Maybe an 91mm Golfer then? Welcome to the boards fred.   :cheers:
« Last Edit: August 15, 2018, 02:20:47 PM by zoidberg »
Re: Fire Damage
Reply #6 on: August 15, 2018, 02:08:39 PM
Could be a 91mm Compact made before 1991?  :think: After all, they only started producing the hook in 1991.
Welcome to MTO. :salute:
Re: Fire Damage
Reply #7 on: August 15, 2018, 02:18:57 PM
Hi fred2892 and welcome to  :MTO: :cheers:
I am glad to hear no one got hurt
And good luck with the rebuild  :tu:
Re: Fire Damage
Reply #8 on: August 15, 2018, 02:46:46 PM
Good to hear no one was hurt.  Sorry to hear about the fire regardless.  About the temper on those 2 damaged SAKs, yes I believe they could very well effected.
gb Offline fred2892
Re: Fire Damage
Reply #9 on: August 15, 2018, 03:58:02 PM
Thanks for all the welcomes.
According to http://victorinox.metodi.me/91mmtools.php
It has a pre 91 corkscrew and pre 92 scissors so I think Don Pablo has nailed it as a pre 91 Compact.
00 Offline Mechanickal
Re: Fire Damage
Reply #10 on: August 15, 2018, 04:03:20 PM
A pre 1991 Compact IS a 91mm Golfer, like zoidberg said.
It was only when they added the hook they started calling it a Compact.
And welcome!!
gb Offline fred2892
Re: Fire Damage
Reply #11 on: August 15, 2018, 04:51:03 PM
Thanks for the correction, like an idiot I never even looked at the Golfer as I presumed it would have a divot lifter or a marker or at least something relating to golf.
fr Offline Ptisuisse
Re: Fire Damage
Reply #12 on: August 16, 2018, 10:19:42 AM
Firmly sitted on my mechanical engineer training, I can assure you that the temper of your blades has not suffered.
To moderately change the properties, just to soften the temper, you need to go above 270° Celsius,
and that leaves a coloration on the steel, which is not the case.
By the way, it's a shame I live in Europe, because I have a lot of 111mm scales to give away.
Glad you are safe. Do not forget to lube your pivots with FDA approved lubricant.
Montblancs are black, swiss army knives are red.
Re: Fire Damage
Reply #13 on: August 16, 2018, 10:26:22 AM
The tip of your yellow knife could easily be put back in better shape on the back of a stoneware plate. Here is a climber I did. No special tools, just elbow grease and patience.
* platengres aa.jpg (Filesize: 63.07 KB)
* climber.jpg (Filesize: 114.8 KB)
gb Offline fred2892
Fire Damage
Reply #14 on: August 16, 2018, 10:43:04 AM
Thanks, it’s good to know the blades won’t be affected. I’ll have a go at improving the blade on the golfer as you suggest. I would never have thought to use a plate though, that’s a new one for me.
I am almost in Europe, I am in Norfolk, England.
« Last Edit: August 16, 2018, 11:08:42 AM by fred2892 »
Re: Fire Damage
Reply #15 on: August 16, 2018, 10:46:35 AM
Sorry to hear about your troubles, mate.
Welcome to MTo!
 :cheers: :tu:
Re: Fire Damage
Reply #16 on: August 16, 2018, 10:47:31 AM
 :D :D :D :D
Re: Fire Damage
Reply #17 on: August 16, 2018, 12:17:00 PM
Almost not in Europe :rofl:
Re: Fire Damage
Reply #18 on: August 16, 2018, 12:45:10 PM
Re: Fire Damage
Reply #19 on: August 16, 2018, 12:47:16 PM
Schrodinger's european country...
Re: Fire Damage
Reply #20 on: August 16, 2018, 01:45:34 PM
Ooooops ?!   MTO being essentially an american/international forum,
I automatically assumed you were outside Europe.
Pardon my french  :D  -  love your fine example of british humor.
I could still afford postage to send you a couple of scales.
However, if your 111 is a slider lock, I do not have a spare slider.
"chin up ! "
« Last Edit: August 16, 2018, 01:52:16 PM by Ptisuisse »
Re: Fire Damage
Reply #21 on: August 16, 2018, 01:49:18 PM
With the correct "plate grit", it works wonders, once you get used to it. A knife remains perfectly usable with only 95% of its main blade.
* 88wengerb.jpg (Filesize: 194.32 KB)
* 88wenger3.jpg (Filesize: 66.67 KB)
* 88wenger2.jpg (Filesize: 58.72 KB)
* 88wenger1.jpg (Filesize: 89.37 KB)
« Last Edit: August 16, 2018, 01:53:05 PM by Ptisuisse »
us Offline Yadda
Re: Fire Damage
Reply #22 on: August 16, 2018, 01:56:45 PM
I am glad to hear Boris made it.  Share a pic of Boris when you gat a chance.  I suspect he has a harrowing fire story to tell.
gb Offline fred2892
Fire Damage
Reply #23 on: August 16, 2018, 02:02:12 PM
Just had a quick try at grinding as you suggested. It’s getting there, a bit more profiling and a polish and it will be good as new.
Unfortunately the 111mm is a slide lock and it’s the slide that’s the tricky part to get hold of.
« Last Edit: August 16, 2018, 02:10:56 PM by fred2892 »
Re: Fire Damage
Reply #24 on: August 16, 2018, 02:04:20 PM
Looking good Fred  :tu: :like: :like:
Re: Fire Damage
Reply #25 on: August 16, 2018, 02:05:54 PM
gb Offline fred2892
Fire Damage
Reply #26 on: August 16, 2018, 02:10:16 PM
Here’s a picture of Boris in his indoor house. He was rescued by the fire brigade and after a vet check has suffered only slight damage to his right eye retina caused by the smoke. This is him in his indoor house where he is today, if the weather was better (it’s raining and cool today) he would be out in the garden eating weeds and attacking cats.
« Last Edit: August 16, 2018, 02:14:03 PM by fred2892 »
Re: Fire Damage
Reply #27 on: August 16, 2018, 02:28:14 PM
Re: Fire Damage
Reply #28 on: August 16, 2018, 02:50:20 PM
Re: Fire Damage
Reply #29 on: August 16, 2018, 03:38:10 PM
Glad to hear Boris has only a small bit of damage :tu:
Will his eye be alright or does
he need work done on his eye :think:
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
