Forum profile
us Offline smiller43147
Forum profile
on: August 17, 2018, 05:40:19 PM
Any trick to setting your birthdate?  I can set the year, but the month and day want to set to 1/1.  If I change them, the year changes to 1918 (not quite that old).
Also, my signature doesn't show up on my posts.
- Steve
us Online SteveC
Re: Forum profile
Reply #1 on: August 17, 2018, 05:49:45 PM
If I remember correctly I think if you switch back to the old forum theme then it should work.
Go to look and layout and then click on the change button for forum theme, switch to Curve. Now try and set your birthday. You can then switch back to the new theme  and see if it worked.
Re: Forum profile
Reply #2 on: August 17, 2018, 05:56:49 PM
Like Steve said I have had to do it a couple of times now
it's a bug in the forum theme.  You might be able to change it by going to Profile > Forum Profile > Look and Layout > Current Theme and switching to SMF Default Theme - Curve.  Change your DOB there, then switch back to the Forum or Board Default theme.
Re: Forum profile
Reply #3 on: August 17, 2018, 05:57:43 PM
Thanks guys.  The date "stuck".  Let's see if the signature works.
- Steve
Re: Forum profile
Reply #4 on: August 17, 2018, 05:59:18 PM
One out of two.
- Steve
Re: Forum profile
Reply #5 on: August 23, 2018, 04:29:50 PM
I'm using the old version, don't know if it has any influence on it, but recently changed my signature without a problem.
wales Offline hiraethus
  • I brake for cake
Re: Forum profile
Reply #6 on: August 29, 2018, 06:14:53 PM
Go to Profile > Modify Profile > Look and Layout, uncheck Don't show users' signatures.
nl Offline Serena
Forum profile
Reply #7 on: November 19, 2018, 03:03:53 PM
Yep, tried to change my birthday. Doesn't work.
Now I'm born in 1918????
Edit: Changing the theme worked. Don't bother.
« Last Edit: November 19, 2018, 03:06:42 PM by Serena »
Re: Forum profile
Reply #8 on: November 26, 2018, 06:59:10 PM
Re: Forum profile
Reply #9 on: November 26, 2018, 07:16:44 PM
nl Offline Serena
Re: Forum profile
Reply #10 on: November 26, 2018, 08:05:04 PM
Re: Forum profile
Reply #11 on: November 26, 2018, 08:11:23 PM
