Question for Vic Caddy owners
it Offline shadowrider
on: August 23, 2018, 04:26:54 PM
Hey folks,
if any of you owns a Caddy or other 58mm model with removable (old-style) ink pen, can you tell me if the latter can be swapped for a toothpick and vice-versa? In other words, is the scale that holds the removable pen the same as a standard scale, or is it specific to that tool?
Re: Question for Vic Caddy owners
Reply #1 on: August 23, 2018, 04:36:37 PM
It's a different scale. It's thicker than the regular scale. You'd need to swap scales if you want a toothpick/tweezers instead of the pen.
Or maybe you're asking something else:
The scale in itself has the same inserts to be attached to the SAK body. You can replace it with any other from a regular Classic.
Reply #2 on: August 23, 2018, 04:43:10 PM
See this:
00 Offline Mechanickal
Reply #3 on: August 23, 2018, 06:25:40 PM
The removable pen is discontinued and desireable...
Reply #4 on: August 23, 2018, 10:03:18 PM
Thanks, but I'm talking about the older removable pen, the kind that comes all the way out like a toothpick.
I don't know if you need thicker scales for that.
* 640x480_Victorinox Caddy.jpg (Filesize: 137.76 KB)
