Tried sharpening the replaceable cutters on my Rebar
MMR · 14 · 1600
dk Offline MMR
For my usage: which mostly involves cutting electrical wires or zip ties, I often found that the blunt edge on the cutters were kind of struggling and didn’t cut all the way through.
So after I tried sharpening them as seen in pictures below, I’m pleasantly surprised with the results. They cut through electrical wire like a hot knife through butter and it’s a lot more of a cleaner cut as well.
I’ll see how well they hold up over time.
But I wouldn’t recommend doing this if you are using your cutters for cutting screws or nails, but not bad for plastic and electrical wires.
But regardless, if all comes to worse, they are easily replaceable, so no big deal
Kind regards,
MMR
- Andrew Ryan
Re: Tried sharpening the replaceable cutters on my Rebar
Reply #1 on: August 24, 2018, 12:18:08 PM
Nice job MMR :like: Let us know how well they hold up :tu: should be fine as long as you are just cutting softer things and thanks for the disclaimer as well ;) :D
dk Offline MMR
Reply #3 on: August 24, 2018, 12:39:31 PM
Just for reference; this is how the same wire was cut before.
As you can see, it was not very pretty cuts, and several times it didn’t even cut all the way through.
And this is the type of wire (came off an old TV from the late 90s / early 2000s):
« Last Edit: August 24, 2018, 02:42:21 PM by MMR »
Kind regards,
MMR
- Andrew Ryan
Reply #4 on: August 24, 2018, 12:56:52 PM
Thanks for the refernce pics MMR :salute: The sharpening made quite a difference I see :o :like:
us Offline Glockfan
Reply #5 on: August 24, 2018, 01:41:26 PM
Great info, thanks :like:
Reply #6 on: August 24, 2018, 01:48:41 PM
Nice job, how did you sharpen them ?
dk Offline MMR
Reply #7 on: August 24, 2018, 02:08:20 PM
I used this “multi function sharpener”; I bought in Aldi ages ago, which was originally designed for drill bits and scissors etc, but I have modified to accept bigger jobs
Kind regards,
MMR
- Andrew Ryan
Reply #8 on: August 24, 2018, 02:32:36 PM
Nicely done.  The cutters are 154CM so they should hold up well.
us Offline Obi1shinobee
Reply #9 on: August 24, 2018, 02:41:42 PM
Reply #10 on: August 24, 2018, 03:38:27 PM
Nicely done  :like: :tu:
Reply #11 on: August 24, 2018, 05:00:31 PM
Nice work! They should hold up fine. I have sharpened the cutters on my Surge a few times.
Reply #12 on: August 25, 2018, 03:26:12 PM
@MMR -a great share and photos.  Thank you for sharing the before results, as the after were so much improved.
 :like: :like: :salute:
it Offline balvenie
Reply #13 on: August 31, 2018, 10:23:46 AM
Didn't know that!  :tu:
I have nothing against corkscrew, i'm Italian!!
