Build Report: Cadet X !
Myron · 35 · 2145
us Offline Myron
on: September 03, 2018, 07:28:43 PM
I decided to jump into my project to build a Cadet X, which is to say a regular Cadet plus scissors.  I obtained a donor Golfer and a brand new Cadet, still in its packaging.  The Golfer cost me $38, but it came in a lot with a Hiker and a Climber that I can give as gifts sometime.  The Cadet cost me $22 brand new.
I disassembled the Golfer and removed the scissors, spring, and liner that I'd need.  I was initially a little confused about liners.  I examined my Pioneer X and both liners were identical, and also differently shaped from the liner that came out of the Golfer.  After thinking about it for a short time, I couldn't come up with any reason why the Golfer liner wouldn't work in a Cadet chassis.  So I just dove in.  The Golfer comes apart:
Driving the last pin out of the Golfer, and disassembling the brand new Cadet.  I can tell you that I had no compunction about disassembling this particular Golfer because it was a beater that had lived a full life and had been neglected.  The brand new Cadet on the other hand....
With everything apart, the difference in shape of the liners is apparent.  I initially thought I'd trim the Golfer liner down to match the Cadet's liner shape, but decided I didn't have the right tools and would likely end up ruining it.  When I couldn't think of any reason it wouldn't work as is, I just decided to use it.  Next came prepping the pin stock.  I learned on my first couple of mod projects that the project knife will assemble much more easily if one end is rounded smoothly.
Next, the pins are inserted into my wooden jig.  The top scale is placed face down, then the opener layer, the opener spring, then the liner on top of that.  Everything is gently tamped down.
Next, the precious and rare 84 mm scissors are added with their back spring, the liner on top, and finally the knife and nail cleaning tool.  The force required to set the scissors back spring is greater than the opener layer, so I move the jig to the vise to hold it securely.
The mystery washer is added before the bottom scale is gently tamped into place.  At this point, the last brass pin is a bit of a trick to line up, but with a little effort, everything lines up and comes together.  The unfinished assembly is then gently removed from the jig.
I was bound and determined to do a better job forming my rivet heads this time, so I built a tool to help.  I cut the end off of an old rat tail file and, using a countersink drill bit, drilled out its end to make a cup-shaped forming tool.  This seemed to work pretty well.  I alternated using this with a 6 oz hammer and a 16 oz hammer, and using the ball peen end of the 6 oz hammer.  I have a block of steel that I put counter sunk holes in to accommodate the sides of the rivets I'm not forming.
After what feels like an eternity of gently peening and forming, and stopping to check snap and opening action, the knife is finished.  It came out great, and is the best (of 3) modding projects I've tackled so far.
se Offline RF52
Re: Build Report: Cadet X !
Reply #1 on: September 03, 2018, 07:39:58 PM
Nice work and pics
Reply #2 on: September 03, 2018, 07:43:48 PM
Excellent work Myron  :like: :rofl:
Reply #3 on: September 03, 2018, 08:09:17 PM
That is fantastic!
us Offline Myron
Reply #4 on: September 03, 2018, 08:31:15 PM
Nice work and pics
That is fantastic!
Thanks you guys!  It was a very satisfying project and only took a couple hours (if you don't count eBay trawling time to track down a reasonably priced Golfer  ;) )
I still want to get better at forming rivet heads on my pins.  I welcome any and all suggestions for improvement here!
Thanks again,
Myron
« Last Edit: September 03, 2018, 09:11:08 PM by Myron »
Reply #5 on: September 03, 2018, 08:40:54 PM
 :like: :tu:
pt Offline FInixNOver
Reply #6 on: September 03, 2018, 09:46:33 PM
Awlsome job Myron! :tu:
Comprehensive and detailed report :like: :like:
Sent from my Redmi Note 5
se Offline kottskrapa
Reply #7 on: September 03, 2018, 09:51:58 PM
Nice work! Really liked awl the pics!
00 Offline Mechanickal
Reply #8 on: September 03, 2018, 09:55:58 PM
Want...
Need extra 84mm scissors first though...
Awesome job!
wales Offline hiraethus
  • I brake for cake
Reply #9 on: September 03, 2018, 09:57:33 PM
us Offline Myron
Reply #10 on: September 03, 2018, 11:20:35 PM
Thank you!   Since posting all those pics I’ve improved the rivet heads on the brass pins.  I put the rat tail file forming tool that I made in the drill press and used it as a spinner.  I’m very happy with the results, and that’s with a home made out-of-round tool.  What I’d like to get is a carbide spinning tool professionally machined.   Anybody know of any sources?
us Offline Simyo
Reply #11 on: September 04, 2018, 12:35:10 AM
Your mod came out great I’m most impressed with the $38 golfer.  Great score.
Reply #12 on: September 04, 2018, 01:25:28 AM
Well done.   :like:
us Offline Myron
Reply #13 on: September 04, 2018, 01:41:23 AM
Thank you Aloha and Simyo!
us Offline CallsignBadger
  • Honey Badger Don't Care
Reply #14 on: September 04, 2018, 01:43:00 AM
 :drool: :like:
us Offline Myron
Reply #15 on: September 04, 2018, 01:03:31 PM
Thank you CallSign!  Nothing like carrying a new VSAK in your pocket to make you look forward to going to work after a long holiday weekend.
Reply #16 on: September 04, 2018, 03:36:46 PM
Come on Vic, produce this SAK.
Reply #17 on: September 04, 2018, 04:06:01 PM
 :iagree:  :like:
We need this!
us Offline Myron
Reply #18 on: September 04, 2018, 11:36:25 PM
I'm thinking I prefer the name Super Cadet to Cadet X.  What do you guys think?
Reply #19 on: September 05, 2018, 02:11:05 AM
I like it
THE SUPER CADET
us Offline Myron
Reply #20 on: September 05, 2018, 04:15:13 PM
Me too!  I think I'll do a poll on this critical subject.  :)
Myron
Reply #21 on: September 05, 2018, 04:35:35 PM
Myron
Yes please.
Reply #22 on: September 05, 2018, 04:36:55 PM
 :iagree: :tu:
us Offline Myron
Reply #23 on: September 05, 2018, 08:46:36 PM
us Offline gustophersmob
Reply #24 on: September 05, 2018, 08:56:00 PM
As I said in the poll thread, really nice job!
The peening looks excellent!
Reply #25 on: September 05, 2018, 08:57:53 PM
Voted  :salute:
us Offline Myron
Reply #26 on: September 05, 2018, 09:30:28 PM
Thanks Gustophersmob and Wspeed!
I'm planning my next Super Cadet X (best of both worlds?) and I think I can make the heads on the pins even better.
Of course I'll report back here with my results....
Reply #27 on: September 05, 2018, 09:32:13 PM
 :popcorn: :like:
Reply #28 on: September 27, 2018, 04:55:42 PM
Looking at this again and  :drool:.  Why did you add a washer on the blade?
  • I brake for cake
Reply #29 on: September 27, 2018, 05:16:17 PM
The blade tang isn't quite as thick as the backspring on the newer knives* and the aluminium liner n the celidor knives is indented to make up the difference.  On an alox scale, which is flat, the washer is added to fill the gap.
* Older SAKs have slightly thicker tangs and the washer/shaped liner isn't required.  You need to be careful about mixing old blades with new liners and vice-versa.
