I do, and smack my knuckles pretty much everytime.
Anyone tried doing it on the swisstool
Quote from: duckman1975 on December 01, 2008, 12:22:32 AMAnyone tried doing it on the swisstool I have! But it was very slow.
When I was reading this article I was thinking that I didn't have the problem with "Knuckle smashing" while opening this tool in the butterfly knife fashion.So I pulled it out of my drawer (it's not my daily carry) and tried it, sure enough "smack" mild pain, almost every time.As I practiced I realized that you can actually open it with only slightly less flair, but much less pain:1: Pull out multitool.2: Hold tool in hand with the gears pointing away from you. The tool should be parallel to the ground, grasping only one handle of tool. The palm of your hand should be pointing down.3: Drop/flick the lower portion of the tool downward.4: Rotate your hand so that the palm of your hand is pointing up and lightly flick the tool open further.5: Grab the other handle and open the pliers the remaining bit.6: Experience a pain-free opening.This actually looks almost as slick as the single motion flick knuckle breaker. Instead you end up with two fluid movements.It can be done.
