No cybertool bit kit?
us Offline G-Dizzle
on: September 24, 2018, 04:33:26 AM
Was comparing some options for my next SAK. Was very much interested in a cybertool until I found out that vic doesnt make any ball detent, double sided bits to go with their cybertool. Does that mean that we can’t have any bits other than the 4 that Vic deems that we need?  ??? I know of the magnet mod but would rather not do that, I would like having bits that are made for the tool to prevent slipping if I am tourquing it.
« Last Edit: September 24, 2018, 04:34:54 AM by gdoolittle »
00 Offline Mechanickal
Re: No cybertool bit kit?
Reply #1 on: September 24, 2018, 07:16:29 AM
There are 8 Vic bits (all used in the XAVT).
There was a thread here once that showed other ball detent bits.
The ball detents were in a slightly different place but worked.
I also remember it was quite an expensive piece of kit...
No time to search for it atm.
ch Offline Etherealicer
Reply #2 on: September 24, 2018, 08:58:21 AM
So far, the only one I'm aware of: KRAFTWERK
I recommend putting a magnet in, then you can use any bits.
Something like the "Red Cycling Products - Micro Pocket Tool"
us Offline GoatDragon
  • SAK 4 life
Reply #3 on: September 24, 2018, 04:28:25 PM
Any advice or guidance on how to magnetize the Cybertool bit driver?
Reply #4 on: September 24, 2018, 07:32:09 PM
By glueing a small rare earth magnet in the driver.
Offline Old man Chris
Reply #5 on: September 24, 2018, 08:00:50 PM
 :like: :like:
IIRC , Whia made or used to make some ball detent bits , but to be honest , a rare earth magnet seems more practical , there are 4mm to 1/4”( 6.? mm bits ) adaptors .
Best Regards,
Chris
Reply #6 on: September 24, 2018, 08:04:29 PM
Those adapters exist, are hard to find, and cost a small fortune for some reason...
no Offline Vidar
Reply #7 on: September 24, 2018, 08:24:03 PM
I believe the Victorinox 4mm bits are manufactured by german Felo. The 8 bits offered by Victorinox should be these: http://www.felo.com/en/catalog/series/sbit/
(Rotate that banner until you see some double sided 4mm bits at 28mm length).
Might also be on their catalogues page 154 (if the webinfo is up to date).
« Last Edit: September 24, 2018, 08:25:43 PM by Vidar »
"Simple is hard"
"Hard is hard too"
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
