Tools explained
Tools explained
on: October 29, 2018, 03:11:06 PM
TOOLS EXPLAINED
DRILL PRESS : A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL : Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh*t'
SKILL SAW : A portable cutting tool used to make studs too short.
PLIERS : Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER : An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW : One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS : Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH : Used almost entirely for lighting on fire various flammable objects in your shop. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race..
TABLE SAW : A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK : Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW : A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST : A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER : Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER : A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR : A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER : A tool used to make hoses too short.
HAMMER : Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE : Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
Micrometer- expensive C clamp designed to show you down to a ten thousandth of an inch how bad you f**ked up
Adjustable wrench - non-parallel jaws guaranteed to be just slightly larger or smaller than whatever fastener you're trying to use it on
MAGNET: A tool used to pick up all the shavings, rust, and welding slag while you're looking for the parts you lost
Welder- A machine used to repair small holes in completely saveable projects but often times Makes the hole much much larger until there is no saving it. Sometimes in very skilled hands it can be used to firmly and permanently attach your project to your welding bench.
MAINTENANCE MAN
A guy who fixes stuff that is working and keeps on fixing it until it doesn't work anymore
SCREW EXTRACTOR : A tool used to break off a hardened piece of metal into a stripped bolt head, ensuring the bolt can never be removed, and turning the object efficiently into scrap.
Son of a bitch TOOL : Any handy tool that you grab and throw across the garage while yelling 'Son of a b*tch' at the top of your lungs. It is also, most often, the next tool that you will need.
It's important to know your tools before you start!
us Offline gerleatherberman
Re: Tools explained
Reply #1 on: October 29, 2018, 03:29:33 PM
Thanks for posting that, Def!
Re: Tools explained
Reply #2 on: October 29, 2018, 03:51:58 PM
se Offline RF52
Re: Tools explained
Reply #3 on: October 29, 2018, 04:02:04 PM
Great explanation :hatsoff:
es Offline ThePeacent
Re: Tools explained
Reply #4 on: October 29, 2018, 04:23:55 PM
 :clap: :rofl:
soooo true :hatsoff:
My toys:
Re: Tools explained
Reply #5 on: October 29, 2018, 04:55:41 PM
I can't argue with any of those  :D
fi Offline AlephZero
  • Smurf smash!
Re: Tools explained
Reply #6 on: October 29, 2018, 08:34:11 PM
Still as funny as it was first posted in circa 2007  :cheers:
"Hoarder of weirdness,
Always posting random things,
I'm AlephZero" :ninja:
Re: Tools explained
Reply #7 on: October 29, 2018, 10:14:07 PM
I'm pretty certain I have posted similar ones before, but as we have this fancy new forum I figured it was worth posting again!
  • Smurf smash!
Re: Tools explained
Reply #8 on: October 30, 2018, 11:22:08 AM
Definitely! :cheers:
Re: Tools explained
Reply #9 on: October 30, 2018, 01:33:26 PM
Awlso, I believe this was your 60k post! Nice way to mark it!
 :cheers: :drink: :tu: :salute:
Re: Tools explained
Reply #10 on: October 30, 2018, 04:47:13 PM
Wow, 60,000 nearly pointless posts!
Good thing there are a lot of you here to keep me amused!   :pok:
Re: Tools explained
Reply #11 on: October 30, 2018, 05:39:38 PM
60K! :ahhh :hatsoff:
My toys:
us Offline twiliter
Re: Tools explained
Reply #12 on: November 24, 2018, 10:42:49 PM
lol, awesome post.  :rofl:
