Re-shaping blade
ch Offline ghiekorg
Re-shaping blade
on: November 05, 2018, 03:24:07 PM
Hi everyone
lately i started to whittle with a SAK but the spear point blade is sometimes a  bit annoying. So i want to reshape it to be more like a wharncliffe blade.
I was thinking of two different cuts (maybe i will keep the small spear point and i will cut the big blade to make it more straight). The red one would be nicer but i could never go straight during the cut and then make it sharp would be a pain in the butt (maybe i can sand it down instead of cutting?). The green one would be much easier and would keep the blade sharp.
Any suggestion?
p.s. any problem in cutting the blade with a dremel? i mean, does the temperature ruin the temper?
* 2018-11-05_15h11_59.jpg (Filesize: 6.43 KB)
00 Offline Sam Lim
Re: Re-shaping blade
Reply #1 on: November 05, 2018, 03:41:42 PM
I think the green will work better and I just love those Wharncliffe blades. It will keep the blade thickest consistent also.  :like: I did the same to my waves too.
* IMG_20181105_224253-912x684.jpg (Filesize: 151.39 KB)
« Last Edit: November 05, 2018, 03:44:19 PM by Sam Lim »
ch Offline ghiekorg
Reply #2 on: November 05, 2018, 03:46:21 PM
Thank you. i also like them a lot. Really sexy   :2tu:
I will give it a try
england Offline Kev D
Reply #3 on: November 05, 2018, 04:18:46 PM
As long as you keep it cool it shouldn't hurt the temper. Just take it slow when cutting it and cool often.
ch Offline ghiekorg
Reply #4 on: November 06, 2018, 02:31:37 PM
Thank you
It seemed it worked fine  :)
00 Offline Sam Lim
Reply #5 on: November 06, 2018, 04:06:14 PM
Thank you
Picture! Or it didn't happen!  :D
ch Offline ghiekorg
Reply #6 on: November 06, 2018, 04:08:19 PM
hahah. It was the first time in my life i used a dremel, so the cut could be better, but i went really slow, like minimum speed and not more than a couple seconds of contact at the time.
* unnamed.jpg (Filesize: 85.31 KB)
wales Offline hiraethus
  • I brake for cake
Reply #7 on: November 06, 2018, 04:25:17 PM
Sanding/grinding the edge off definitely works.  Or you can get the edge straight-ish with a cutting disc then use a coarse whetstone/diamond stone to create a new straight edge.
00 Offline Sam Lim
Reply #8 on: November 07, 2018, 02:14:24 AM
 :like: I assume there a new nail nick?
ch Offline ghiekorg
Reply #9 on: November 07, 2018, 09:14:43 PM
Yes there is but I left it intentionally on the other side not really nice, I only have the basic dremel disc and it’s quite large. I should fix it one day. At least it works!
Reply #10 on: November 08, 2018, 07:21:02 AM
Looks like a great job  :tu:
And I think recreating the nail nick is an impossibility for us modders!  :(
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
