SAKs put away while I try something different...
zrxoa1 · 35 · 2524
us Offline zrxoa1
on: December 03, 2018, 01:23:48 AM
Not sure if this is proper place for this. Mods feel free to move if need be!
I decided to try something different. For over a year I had been carrying my Wenger SI nearly every day.  I did put it in the drawer every now and then and try out one of the other SAKs in my tiny collection, but always went back to the SI.
Several months ago I decided to start carrying my PX instead. Just your standard silver and I ground off the key ring nub.
A few weeks ago, after someone borrowed my PX and scratched the blade, I decided to add a beater knife to my carry, for rough use. I used a slip a fellow MT.O member gave me.
All has been well, but I admit to a wandering eye. I had been looking at the Boker Tech Tools for some time, but none had caught my eye because I don’t like the corkscrew.   Well then I saw where CountyComm commissioned a special run of the City 2 from Boker, replacing the corkscrew with a Phillips driver AND limited number made. So I grabbed one. Not as a collector piece but as a user.
Once it arrived I have to admit to liking it. The blade is awesome, the black G10 scales rock and I can easily take it apart to clean or mod.  :tu:
I decided to carry it solely for the rest of this year. Basically a month. Hopefully that will give me the info on how rugged it is. I already have some mod ideas, but those will have to wait.
So until next year, my SAKs are tucked away. I had actually started carrying my MT.O Pioneer X when not at work. Using a 3D printed dangler clip, I used it for my weekend carry. Saved the old PX for work use.
I got a start using the Boker this weekend. Nothing major, but it’s getting used. I also removed the pocket clip for now as I can’t use it at work and it’s light enough that it doesn’t bug me being in my pocket.
I’ll let you know after New Years if I will continue with it or go back to my SAKs.   If any of you have any insight on dealing with the Tech Tools or modding, hit me up.
Mod wise I’d like to replace the serrated blade with either the Vic can opener/flat blade or the 93mm inline awl. I do miss having that awl. I actually used it a lot!!
You all have a great week!
« Last Edit: December 03, 2018, 01:27:13 AM by zrxoa1 »
Re: SAKs put away while I try something different...
Reply #1 on: December 03, 2018, 01:43:31 AM
I was eyeing one of those the other day, as well.
I would definitely remove the clip, too.
Interested to hear your thoughts over time!  :cheers:
us Offline Rapidray
Reply #2 on: December 03, 2018, 01:49:13 AM
G10 scales are one of my favorite materials.  :tu:  :popcorn:
us Offline gustophersmob
Reply #3 on: December 03, 2018, 02:43:43 AM
I've looked at these several times, but never could pull the trigger. The corkscrew was one reason, so it's nice to know there's a Philips option.
Couple of questions:
From the pics I've seen it looks like the serrated blade/screwdriver does not open completely 180 degrees. Is that true? If so, seems like a bad injury waiting to happen using that as a screwdriver.
Second, are the back springs flush with the liners?
Third, any overall thoughts on its fit and finish, particularly compared to your pioneer x or SI?
Thanks!
us Offline zrxoa1
Reply #4 on: December 03, 2018, 03:11:38 AM
Thanks!
You are correct, that blade only opens so far. I don’t like that, but I knew it going in.
The springs and liners are not exactly flush, but pretty dang close. They feel like they are...
I think it is as nice as my SAKs.
us Offline Rapidray
Reply #5 on: December 03, 2018, 08:05:07 AM
Is there a reason the blade is that way??? Thanks
us Offline zrxoa1
Reply #6 on: December 03, 2018, 08:17:03 AM
If you are referring to the serrated blade, I don’t know. That is just the way they made it, for some reason.
Another guy here, Hobie I think he’s called, swapped that blade out for an inline Phillips from a SAK. He had a different model Boker than I have, but it was basically same tool as mine.
There is a video of it on YouTube.
Reply #7 on: December 03, 2018, 08:19:24 AM
You can put a Vic can opener in its place.
https://forum.multitool.org/index.php?topic=67166.0
I've been curious about these. I'd rather have a Ruike or Sanrenmu branded one. They also make a 111mm one. They are appealing for sure. :cheers:
00 Offline Dutch_Tooler
Reply #8 on: December 03, 2018, 08:57:43 AM
Just yesterday I added a post to the thread linked in the previous post, to show that a 93 mm awl can be added with little modification (not needed on the tang).
My thoughts on the Tech Tool in general:
- The build quality of the implements seems to be on a par with Victorinox.
- I like the wide main blade.
- I have the green scales and these are very grippy, probably no different to the black ones in that aspect.
- I thought I could get used to the small serrated blade but I haven't - extended at the full 150° or so, it is awkward to use, especially as a screwdriver where index fingers are in danger of being pinched and cut. The replacement with the 93 mm awl referred to above was mainly in response to a question, but could end up as a permanent fixture (or perhaps a small blade).
- The implements are a tad more widely spaced than in comparable Vic offerings. There's pros and cons to that. Better cleaning, but more space required in-pocket and more prone to attracting copious amounts of pocket lint...
- I like the pocket clip, but it can be easily removed if you don't.
- Some criticism has been leveled at what some call the 'pocket shredding' glass breaker. I haven't had that experience yet, but then, I use the clip...
Cheers!
Dutch_Tooler
us Offline zrxoa1
Reply #9 on: December 03, 2018, 09:30:19 AM
Thank you!!!!  Now to source a 93mm awl!!!
Reply #10 on: December 03, 2018, 01:06:43 PM
Thanks!
Thanks for this!
Its seems there are several viable ways to mod that little blade. I may have to finally pick one up
us Offline zrxoa1
Reply #11 on: December 03, 2018, 02:15:42 PM
Yep.  It seems a fine little beastie!!
pt Offline MacGyver
Reply #12 on: December 03, 2018, 03:12:58 PM
It looks nice, but not really my kind of thing... For edc at least...
Hope it will work out great for you  :tu:
us Offline Rapidray
Reply #13 on: December 03, 2018, 03:43:14 PM
Thanks and great information!  :tu:
us Offline zrxoa1
Reply #14 on: December 08, 2018, 05:30:19 AM
Ok, have a 93mm awl on the way, to replace that belt cutter. Can’t wait!!
So far with the Boker, I am missing the scissors of my PX.
us Offline zrxoa1
Reply #15 on: December 11, 2018, 04:43:54 AM
Got the awl installed today...
Came at a price... haha
us Offline Rapidray
Reply #16 on: December 11, 2018, 05:52:45 AM
Very nice and a bigger improvement!  :like: :tu:
us Offline zrxoa1
Reply #17 on: December 11, 2018, 05:56:44 AM
There is one drawback I neglected to mention...
You need to open the awl first in order to get the cap lifter/flat head tool open.
Definitely not a deal breaker for me. Just thought I’d better mention it!
Reply #18 on: December 11, 2018, 05:58:44 AM
Great mod! :like:
Infinitely more useful than that accident waiting to happen. What about the awl width? Did you need washers or was it just a drop-in?
us Offline Rapidray
Reply #19 on: December 11, 2018, 05:59:31 AM
Oh, like you said not a deal breaker for some. :like:
us Offline zrxoa1
Reply #20 on: December 11, 2018, 06:26:27 AM
Great mod! :like:
I left the lanyard ring in as a spacer. The awl and the original tool are pretty much same thickness. I have not officially measured yet.
It could probably use a tad thinner spacer but it’s working for now!
Reply #21 on: December 11, 2018, 09:11:32 AM
And...
The awl has blood bonded with you already ...  :cheers:
Hope it works out. It doesn't touch the opener? If it did it might become a bit blunt right there.
Cheers!
Dutch_Tooler
us Offline zrxoa1
Reply #22 on: December 11, 2018, 10:09:07 AM
And...
I don’t think the sharp edge is hitting the opener, just the upper edge rests on top of the cap lifter.
« Last Edit: December 11, 2018, 10:10:28 AM by zrxoa1 »
us Offline VICMAN
Reply #23 on: December 11, 2018, 12:55:13 PM
Nice mod zrxoa1! :like: :tu: :tu:
us Offline Rapidray
Reply #24 on: December 11, 2018, 02:04:20 PM
 :iagree: 100%  :hatsoff:
us Offline zrxoa1
Reply #25 on: December 11, 2018, 02:35:39 PM
Thanks folks!!  Wasn’t all that difficult. Those that do the SAK mods are king!!  But hey, it’s a start!!
us Offline zrxoa1
Reply #26 on: December 11, 2018, 03:13:11 PM
So far, carrying the Boker for 11 days, the only thing I can say I’ve missed versus my Pioneer X are the scissors. Last night I needed them badly.
I use them for a number of things, but I gouged my finger pretty good adding the awl before work and had a flap of skin that kept getting caught on everything and I needed the scissor to excise that little piece of tissue!!
I ended up using my thumbnail like a cutting board and used the awesome blade of the Boker to gently cut that flap off.
I will admit I miss the “feel” of the alox in my pocket. I tend to fidget with it. However, the G10 of the Boker does have its appeal.
In all honesty, I foresee returning to the PX in January, because the Boker, as good as it is, is really a compromise. With the PX I have my blade, awl and the two opener slash screwdrivers.  Plus those wonderful scissors!!
I had to sacrifice the small flathead for the awl. I do use the awl a lot when I was carrying the PX.
The Boker is very nice and easily customizable, compared to the SAK, but not as refined.
I will probably need to just break down and pay someone to drill out the rivets on my PX and put it back together with torx screws. Then I’d truly have what it is that I want!!
us Offline Rapidray
Reply #27 on: December 11, 2018, 03:47:59 PM
You are right about the G10...a totally different feel and as my son would say warm feeling. I prefer G10 and have a set. Thinking of this one but loosing the fish scaler. Or two layers.
us Offline zrxoa1
Reply #28 on: December 13, 2018, 11:06:42 PM
Not a great video, but does show the awl after install...
us Offline ezdog
Reply #29 on: December 14, 2018, 12:23:08 AM
I have the only other one that Boker offers without the Corkscrew as I have Zero need for one and it sort of bugs me having them too.
I was able to play with them all art a local store before jumping on board too and although that serrated thing is mildly terrifying for sure I really like the knife overall anyway.
Mine has Pliers like the Mechanic pretty much and bigger scissors that have worked fine for me although I will admit I NEVER think to use scissors on a knife for some reason anyway?
This and a nice right angle Phillips,an Awl and larger straight driver/opener  and really nice fit & Finish and what is there to not like?!?
I also love the Clip and this is something I honestly wish was an option on SAKs too.
« Last Edit: December 14, 2018, 12:24:57 AM by ezdog »
