(Not) My Design for a Multitool
J-sews · 136 · 19975
Offline supratentorial
Re: (Not) My Design for a Multitool
Reply #90 on: May 24, 2007, 06:34:56 AM
My condolences.
Offline Tom Munch
Reply #91 on: May 24, 2007, 06:43:00 AM
Thanks, guys.
Yes, my wife's dad is still alive.  He's declining too, but he should have a few years left we can fish & tell tall tales over a beer.
I've lost quite a few folks who I was close to over the last few years, so I'm not as sad as I might be at losing my wife's mother.  I buried my own father just a year & a half ago.  This is all just part of life I suppose.  As a performer I have to push it down so that I can smile & give my all on stage.  I find time to grieve though - we all do in our own way.
Tom
Offline Tom Munch
Reply #92 on: July 14, 2007, 06:28:59 PM
I'm still working on my cardboard model of this tool.  This summer has been tremendously busy - been working 7 days a week since Memorial Day.
Tom
Offline Tom Munch
Reply #93 on: September 12, 2007, 05:03:00 PM
I'm ready to get back to this now.  I'm sorry if I've been leading folks on a bit.  I need to find a good machine shop to do the work for me.  I'm still afraid it will be a monster & very unuseable, but it's worth a shot.
Tom
Reply #94 on: September 13, 2007, 04:43:17 AM
Yay!! :cheers:
Offline trickknife
  • Deputy Dog
Reply #95 on: September 13, 2007, 05:23:11 AM
Now how to add wire cutters into that jaw - either deep in the jaw or on the back somehow like I've seen on other tools.
Any ideas, guys?
Tom
Hi Tom,
I saw some wire cutters that work in a similar manner to the wire strippers.  I'll try to explain it here.  Let me know if it isn't clear.
1.  open up the jaw about 5-10 degrees.
2.  (with a carbide drill bit) drill a hole at angle into the jaws (away from the pivot point/rivet).  The hole must be drilled tangent to the travel of the jaws. (this is getting to hard to explain).
3.  anyway, if you then stick a wire in that same hole and close the jaws, it should cut the wire.
If you drilled a hole straight through, that would work, but and angled hole acts as a wire stripper also.
Does that make sense?
« Last Edit: September 13, 2007, 05:24:47 AM by trickknife »
Offline Tom Munch
Reply #96 on: September 13, 2007, 07:30:09 AM
trickknife,
I've read your description several times, but I'm still not picturing what you're describing.  Do you mind sketching it a bit?
Tom
Offline trickknife
  • Deputy Dog
Reply #97 on: September 13, 2007, 07:58:28 AM
Here's an attempt at drawing in 3D.
In "cutter 2" the jaw is pivoted so that the jaws will be closed (disregard the sloped hole for a second).
You open up the jaws slightly (about 5 or 10 degrees) and then drill a hole at an angle as shown in the image "cutter 1".
To use the wire cutter, you open the jaws up to this position (where you can see through the two holes) and insert your wire.
Then you close the jaws and squeeze on the handles.  It should go back to the position in "cutter 2" and the wire should sheer off.
Is that better?
Rick
* cutter 2.jpg (Filesize: 42.43 KB)
* cutter 1.jpg (Filesize: 41.53 KB)
Offline Tom Munch
Reply #98 on: September 15, 2007, 04:55:54 PM
trickknife,
That's a good idea, but I don't know if either of the Knipex heads I'm looking at have sufficient overlapping material to do this.
Offline Tom Munch
Reply #99 on: September 15, 2007, 04:57:19 PM
Maybe a wirecutter could be implemented into the back where the tools scissors a bit.
Tom
Offline Tom Munch
Reply #100 on: September 15, 2007, 04:58:07 PM
A carbide insert could even be fastened into the jaws somehow I think.
Tom
Reply #101 on: September 15, 2007, 05:24:22 PM
Tom
Carbide inserts, like some of the Gerber tools have?
Offline Tom Munch
Reply #102 on: September 15, 2007, 05:39:46 PM
Is that do-able, Bob?
Reply #103 on: September 15, 2007, 06:08:34 PM
Two questions occur to me about adding wire cutters to these tools:
1) Location of the cutters?
2) Pivot tightness?
Of the two, the Pivot Tightness question may be the real hang-up. For bypass wire cutters to work properly (and not let the wire squish in between the cutting surfaces) there needs to be very little slop between the plier jaws.
I've never handled one of these Knipex tools before. They look like the design requires a certain amount of looseness between the jaws, and between the two handles.
* index.jpg (Filesize: 22.24 KB)
Offline Tom Munch
Reply #104 on: September 15, 2007, 06:12:42 PM
That's a good point, Bob, but they are actually pretty accurate because of the locking design of the adjustable slider.  That said, it still may be very difficult to get the precision necessary to have two blades meet precisely enough to cut well.  The best we can hope for may be just the ability to cut solid wire & not stranded wire.
Tom
Offline Tom Munch
Reply #105 on: September 15, 2007, 06:19:28 PM
Re-reading your post I agree that there is too much slop for a bypass-type cutter.  I suppose there is too much slop for a two-blade diagonal-type cutter then.  I wonder if a single blade coming in contact with a flat surface (I've forgotten the designation for this) would work.
Tom
Offline Tom Munch
Reply #106 on: September 15, 2007, 06:21:48 PM
Oh yeah...it's Anvil.
Reply #107 on: September 15, 2007, 07:15:24 PM
Yes, I was wondering about the anvil type myself.
Offline Tom Munch
Reply #108 on: December 01, 2007, 04:03:36 PM
So I haven't returned to this design in quite some time.  Part of that is because I don't mind carrying a couple of specialized tools in my bag, & part of that is because I've been taking care of surgery-recovering relatives this Fall.  I promise I won't let it go completely though.  Stay tuned.
Tom
Reply #109 on: December 01, 2007, 07:19:07 PM
We understand...great minds can't be rushed  :)
Offline Tom Munch
Reply #110 on: December 01, 2007, 07:25:08 PM
Great minds - ha!  No one's ever said that about me before.
Reply #111 on: December 01, 2007, 07:29:34 PM
Bob must want something. :think: :D
Reply #112 on: December 01, 2007, 07:33:52 PM
Nope. I just want to cover my butt for when someone brings up a certain Spirit project that I started 8 months ago  :P
Offline Tom Munch
Reply #113 on: December 01, 2007, 09:49:03 PM
Oh yeah!  Whatever happened to that?  ;)
Reply #114 on: December 01, 2007, 09:52:00 PM
Reply #115 on: December 18, 2007, 06:15:43 AM
http://cgi.ebay.com/FIREFIGHTER-CUSTOM-MADE-POCKET-TOOL-100-QUALITY_W0QQitemZ140189121387
According to the seller:  "It’s the next best thing to having an iPhone"  ::)
I think we can do better.
* munch.JPG (Filesize: 24.54 KB)
Offline Tom Munch
Reply #116 on: December 18, 2007, 06:18:55 AM
Yes, I think we can too.  :salute:
Offline damota
Reply #117 on: December 19, 2007, 01:40:47 AM
Is it expensive bloatware? That only can be used with DRM nuts and screws?  >:(
Dave
Reply #118 on: December 19, 2007, 04:02:03 AM
By golly though, you have to give the fellow credit for trying!
Basically he's taken individual tools and made them into a single device which is more useful to his trade (firefighter). Quite honestly, the result appears to be more functional than some of Tim Leatherman's early prototypes ;)
Reply #119 on: December 19, 2007, 04:10:08 AM
...by the way, I sent off a message to the fellow, asking him to drop by and tell us about his device.  :)
January Goal: $300.00
Due Date: Jan 31
Total Receipts: $96.97
PayPal Fees: $5.86
Net Balance: $91.11
Below Goal: $208.89
30%
January Donations
