30-day axe challenge
Nix · 2826 · 83982
au Offline TazzieRob
Re: 30-day axe challenge
Reply #2730 on: November 01, 2019, 08:59:10 AM
Day 32
I'm about 15mm from my hopeful end: 700mm. Going to take my time from here
Sent from my SM-G970F using Tapatalk
Reply #2731 on: November 01, 2019, 01:33:54 PM
Looking good Tazzie  :like: :tu:
us Offline Rapidray
Reply #2732 on: November 01, 2019, 01:52:13 PM
Day 32
Awww...ok. I see how you are doing it!  :like: :cheers:
00 Offline Borg
Reply #2733 on: November 01, 2019, 05:40:57 PM
It is a very nice looking handle. Spalting is not a term I'd heard before a few years ago. As the types of wood like maple and birch that seem to be common in the Northern hemisphere are introduced here, a similar type of thing happens with our native Sassafras. The darkening happens in the heart wood, so the term used is Blackheart Sassafras. It causes nice figuring and shades
https://www.wood-database.com/blackheart-sassafras/
Unless you don't plan on using it for another year, why not make a mask now?
Yeah it is really nice, when i cut my firewood i always throw some of the interesting ones to the side, like this bit of Beech
I also really like the end grain on them and wanted to make a set of scales for a sak with it, i just don't think it will hold up very well and it will have no strength,  i suppose plenty epoxy would hold it all together though  :dunno:
I wasn't serious about waiting a year to make the mask, i will get round to it eventually  :cheers:
00 Offline Borg
Reply #2734 on: November 01, 2019, 05:44:02 PM
Day 29
se Offline RF52
Reply #2735 on: November 01, 2019, 05:44:20 PM
You could send it to someone to get it stabilized :tu: That would make it plenty strong for scales :cheers:
Reply #2736 on: November 01, 2019, 05:46:08 PM
Or make it stronger by glueing
another piece of wood to the back of it :dunno:
Reply #2737 on: November 01, 2019, 05:46:46 PM
Nice pic Borg  :like: :tu:
00 Offline Borg
Reply #2738 on: November 01, 2019, 05:53:14 PM
Would that work with thin end grain though ?  would be great if it did  :tu:
Good thinking batman, a nice thin bit of beech should match the colours, might not even notice it  :tu:
Reply #2739 on: November 01, 2019, 05:57:19 PM
Glad to help Borg  :cheers:
se Offline RF52
Reply #2740 on: November 01, 2019, 06:06:58 PM
I think it would, as the stabilizing is filling the wood with some kind of resin/epoxy :tu:
us Offline Rapidray
Reply #2741 on: November 01, 2019, 06:15:05 PM
That is some great looking spalted wood.  :cheers:
us Offline Rapidray
Reply #2742 on: November 01, 2019, 06:15:32 PM
00 Offline Borg
Reply #2743 on: November 01, 2019, 06:18:15 PM
True  :tu:  i had a quick check how to do it myself, i just need an hvac pump and a vacuum chamber apparently,  neither of which i have.. i will have a look around and see if anyone local can do it, i like this wood but rarely use it for anything because its so brittle, i now have options though, cheers guys  :salute:
00 Offline Borg
Reply #2744 on: November 01, 2019, 06:19:50 PM
Thanks Ray, the man with a van full of hvac pumps but 2000 miles away  :rofl:
se Offline RF52
Reply #2745 on: November 01, 2019, 06:31:11 PM
I was thinking that myself when I found a piece of birch with a very nice pattern, but it got scrapped because of how soft the wood gets(rotten). A cool thing about stabilized wood is you can get it colored when stabilizing it :like: you can't really do it after it's stabilized though :facepalm:
If you go through with it, I can't wait to see :popcorn:
nz Offline Syncop8r
Reply #2746 on: November 01, 2019, 08:18:45 PM
Did anyone else look for the outline of their country on that piece of wood?
Reply #2747 on: November 02, 2019, 03:11:44 AM
Reply #2748 on: November 02, 2019, 08:45:33 AM
This wood really got character, would love to see it work out for some kind of scales.  :tu:
Reply #2749 on: November 02, 2019, 08:48:13 AM
I remembered reading something about this, and was wondering how strong is the vacuum chamber so there is enough negative pressure inside the wood to suck in all the resin.  Must be some kind of a hardcore gear I presumed?  :think:
se Offline RF52
Reply #2750 on: November 02, 2019, 10:47:33 AM
Soft wood might shrink if I'm not mistaken because of the pressure.
Reply #2751 on: November 02, 2019, 11:24:41 AM
Thanks to that, I have no idea.  Nowadays I see a lot of fancy scales, some looked dyed, but others I am not even sure whether they are resin permeated or not.
00 Offline Borg
Reply #2752 on: November 02, 2019, 08:17:50 PM
It's worth looking into i think, there are so many beautiful woods out there that we wouldn't consider using otherwise, even bone would benefit from being stabilized probably, i think basically enough vacuum to remove air and replace it with resin..no clue what pressure that is though :dunno:
8)  pic!    :like:
Thanks David  :salute:
 :D the beauty of it is, if you cut a few mill off it it will change the map :tu:
00 Offline Borg
Reply #2753 on: November 02, 2019, 08:20:27 PM
Day 30  Woohoo  :cheers:
Reply #2754 on: November 02, 2019, 08:40:55 PM
Reply #2755 on: November 02, 2019, 08:45:36 PM
Gorgeous pic and view And
Congratulations on reaching day 30 Borg  :cheers:
se Offline RF52
Reply #2756 on: November 02, 2019, 10:27:30 PM
Good job :hatsoff:
us Offline Rapidray
Reply #2757 on: November 02, 2019, 10:36:52 PM
Love that handle and great photo!  :like: :cheers:
00 Offline Borg
Reply #2758 on: November 02, 2019, 11:57:29 PM
Thanks guys  :cheers:
Reply #2759 on: November 03, 2019, 12:52:01 AM
You sure take good pics Borg!     8)      :like:
March Goal: $300.00
Due Date: Mar 31
Total Receipts: $60.41
PayPal Fees: $3.45
Net Balance: $56.96
Below Goal: $243.04
19%
March Donations
