Rescue tool without Victorinox Swiss Made Stamp
us Offline FolderBeholder
on: February 22, 2019, 03:43:06 PM
My new-to-me Rescue tool doesn't have the Swiss Made stamp on the main blade at the left of the thumb hole which I thought was an indicator that it's fake.
It looks like the one they use in the Victorinox video.
Mine:
Thoughts?  :think:
« Last Edit: February 22, 2019, 04:34:49 PM by FolderBeholder »
Re: Rescue tool without Victorinox Swiss Made Stamp
Reply #1 on: February 22, 2019, 04:09:20 PM
Update.  This review helped me understand just now that mine is real:
https://www.swissarmyknights.com/articles/2008/86-november-2008/491-fake-rescue-comparison
Apparently the thumb hole is evolving and earlier ones were oval shaped, plus the Swiss Made stamp wasn't on those earlier ones at the left side of the thumb hole.
« Last Edit: February 22, 2019, 04:27:27 PM by FolderBeholder »
00 Offline Mechanickal
Reply #2 on: February 22, 2019, 04:10:37 PM
Uh, yes. Exactly.
I would have posted that if I noticed this thread sooner :D
Reply #3 on: February 22, 2019, 04:14:15 PM
Uh, yes. Exactly.
No worries.  I just wanted to be sure I have an authentic one.
Reply #4 on: February 22, 2019, 04:16:08 PM
By the way, the swiss made stamp can be there. But only barely visible when opening the blade about 90 degrees. It would be on the tang as usual but hiddin behind liners and the glassbreaker.
Please do check! :popcorn:
Reply #5 on: February 22, 2019, 04:22:45 PM
It's there!  There's some oil there that is making it hard to read.
Reply #6 on: February 22, 2019, 04:23:59 PM
:woohoo: 8)
:2tu:
Reply #7 on: February 22, 2019, 04:25:58 PM
:woohoo: 8)
:2tu:
Thank you!
I guess it's the newer ones that have the stamp to the left of the thumb hole.  It worried me when it wasn't there.
Reply #8 on: February 22, 2019, 04:31:54 PM
Top box, oval thumb hole.
Bottom box, rounder one with Swiss made stamped to the left of the thumb hole:
Left box newer Rescue tool.
Right box older Rescue tool.
Reply #9 on: February 22, 2019, 04:40:05 PM
Great refference and comparison shots Lisa! Might help others out there :2tu:
Reply #10 on: February 22, 2019, 04:51:29 PM
:hatsoff:
us Offline Rapidray
Reply #11 on: February 22, 2019, 05:03:20 PM
Great information there! And nice score!  :like: :tu:
Reply #12 on: February 22, 2019, 05:42:38 PM
Thanks RR!  :cheers:
us Offline Rapidray
nl Online Reinier
Reply #14 on: February 22, 2019, 09:53:22 PM
us Offline VICMAN
Reply #15 on: February 22, 2019, 10:19:30 PM
Congratulations on the new Rescue Tool FB! :like: :tu: :tu:
I have 4 older ones with the oval thumb hole. Mine all have the Swiss Made stamp to the left of the thumb hole if you are looking at it in the closed position..
Here are 2 pictures of one of them
« Last Edit: February 22, 2019, 10:28:47 PM by VICMAN »
Reply #16 on: February 22, 2019, 11:28:50 PM
Thank you Vicman.  It appears that they made oval ones with and without the Swiss Made stamp.  :cheers:
id Offline jaya_man
Reply #17 on: February 23, 2019, 12:10:57 AM
Nice score Lisa... :drool:
Vicman, the thumbhole on the pic you shared is more rounder... indication of a newer model? :think:
us Offline VICMAN
Reply #18 on: February 23, 2019, 12:15:50 AM
    Quote
Mine is an older model. I bought 4 of them shortly after they first came out.
If you type Victorinox Rescue Tool Test Report by James E. Triplett in the search window you will see 3 reviews
Initial Report - December 19, 2008
Field Report - April 24, 2009
Long Term Report - June 9, 2009
and if you look at the pictures of the Rescue Tool reviewed it has the same oval thumbhole that mine has.
« Last Edit: February 23, 2019, 12:59:01 AM by VICMAN »
Reply #19 on: February 23, 2019, 02:34:52 AM
Yours does look like that one in his early reports.
I'm sure perplexed.  :think:
Here are our thumb holes side by side:
I wonder if mine is earlier.  Then they made the hole a little less elongated and put the stamp on.  Thoughts?
Reply #20 on: February 23, 2019, 08:26:14 AM
This one was made in 2011
us Offline VICMAN
Reply #21 on: February 23, 2019, 03:21:22 PM
I am perplexed too....I don't know how long the elongated hole was made
My 4 were bought in either 2007 or 2008...They may have made the first ones with the elongated hole for a short time before switching to the oval hole because the video has one with the elongated hole and I am pretty sure the video was made in 2007.
« Last Edit: February 23, 2019, 03:23:41 PM by VICMAN »
id Offline jaya_man
Reply #22 on: February 23, 2019, 03:42:53 PM
It was mentioned in SAKwiki that the thumbhole was redesigned in 2007...
http://sakwiki.com/tiki-index.php?page=Trekker
Maybe leftover parts stock was stil used until they ran out?
Reply #23 on: February 23, 2019, 03:57:55 PM
Probably.
Also notice that the new Soldier model came out in 2008, which shares it's blade design with the Rescue Tool.
So I'd guess they revised the blade in 2008 (end 2007) to be used with the Soldiers.
It makes sense that they'd use remaining stocks for the Rescue Tool, since the Soldier was not meant to receive that design of blade.
id Offline jaya_man
Reply #24 on: February 23, 2019, 03:58:43 PM
Here’s some interesting articles...
https://www.swissarmyknights.com/articles/2009/april-2009/428-oht-variants
https://www.swissarmyknights.com/articles/2007/390-new-and-old-oht-comparison
Based on the readings, I assume that the elyptical tumbhole was made between 2003-2007...
In fact, I’ve only ever seen 2 types of OHO thumb holes... the elyptical one with the usual tang stamp... and the more rounded one with Victorinox Swiss Made to the left of thumbhole...
Reply #25 on: February 23, 2019, 04:27:04 PM
Good work gentlemen!
I now think mine was one of the earliest versions, then Vicman's are some of the very first with the new design.  :tu:
us Offline VICMAN
Reply #26 on: February 23, 2019, 04:29:26 PM
Probably.
That all makes sense Mechanickal. :cheers:
Which means my Rescue Tools were bought in 2008. :D
« Last Edit: February 23, 2019, 04:39:13 PM by VICMAN »
us Offline VICMAN
Reply #27 on: February 23, 2019, 04:30:13 PM
Thanks for posting the articles jaya! :cheers:
us Offline VICMAN
Reply #28 on: February 23, 2019, 04:30:36 PM
I agree FB! :cheers:
be Offline Ivo
Reply #29 on: June 19, 2019, 02:10:24 PM
I'm looking so long for this model but I can't find it , this is my missing link in my yellow rescue series  :hatsoff:
Total Receipts: $105.65
PayPal Fees: $6.36
Net Balance: $99.29
Below Goal: $200.71
33%
