SAK Exploded / Dismantled Photos
au Offline Huntsman
Re: SAK Exploded / Dismantled Photos
Reply #60 on: December 21, 2019, 12:40:50 AM
« Last Edit: December 21, 2019, 12:53:05 AM by Huntsman »
us Offline Simyo
Reply #61 on: December 23, 2019, 04:17:31 AM
Does anyone have any disassembled photos of a 91mm with a long nail file.  I’m trying to figure out where to put the extra liner holes.
id Offline jaya_man
Reply #62 on: January 08, 2020, 03:12:35 PM
Hey Simyo, were you able to find answers to your query above?
id Offline jaya_man
Reply #63 on: January 08, 2020, 03:15:07 PM
Hunstman, I’ve never came across a 58mm model with keyring attachment on the liner... As far as I know, its always integrated with the backspring... Do you have a sample?
id Offline jaya_man
Reply #64 on: January 08, 2020, 03:16:38 PM
Here’s a Locksmith broken down for parts...
Been planning to add a wood saw to a rescue tool... interesting to note that the blade, wood saw and metal file backsprings are interchangeable since they’re exactly the same shape (except for those that accomodate backtools).
In fact, I used the backspring that sits below the woodsaw, blade and opener layers to make a Centurion/Adventurer for kitchen duty stuff...
us Offline Simyo
Reply #65 on: January 09, 2020, 06:40:58 AM
I got a picture of one on Facebook and I think my parts supplier found the original liners.  When o get back to that project I’ll post a photo to have in the collection
id Offline jaya_man
Reply #66 on: January 09, 2020, 08:57:36 AM
Wenger PTC...
Pin diameter is 1.96mm ≈ 2mm... One end of the pins is solid (typical of Wenger)... While the other end has a bushing (similar to Victorinox)...
Reply #67 on: January 09, 2020, 01:52:04 PM
Nice ones jaya :like: :tu:
au Offline Huntsman
Reply #68 on: January 09, 2020, 05:33:31 PM
Hunstman, I’ve never came across a 58mm model with keyring attachment on the liner... As far as I know, its always integrated with the backspring......
No - Not quite sure what I was thinking when I wrote that but it's wrong!!
Apologies
id Offline jaya_man
Reply #69 on: January 09, 2020, 05:41:00 PM
No apologies required buddy... :cheers:
id Offline jaya_man
Reply #70 on: March 15, 2020, 07:14:16 AM
Rescue Tool + wood saw...
Reply #71 on: March 15, 2020, 02:37:23 PM
 :like: :tu:
id Offline jaya_man
Reply #72 on: March 15, 2020, 05:55:55 PM
au Offline Huntsman
Reply #73 on: March 15, 2020, 11:12:39 PM
Rescue Tool + wood saw...(Image removed from quote.)
Aha - So the removable tools have a protective ring around the pins/rivets - Fascinating - Thanks JM
Offline Cleanser
Reply #74 on: March 16, 2020, 09:36:49 PM
Anyone know if the cap lifter / screw driver on a 91mm such as the compact the same as on an 84mm such as a waiter?
If not, which one is being added to 93mm mods?
Thanks!
za Offline Max Stone
Reply #75 on: April 14, 2020, 11:54:04 PM
Sorry for the late reply Cleanser. The Combo tool on 84mm and 91mm is a different size. Not sure what 93mm modders are using. Probably the 91mm as the 84mm will drop down too low when closed.
Reply #76 on: April 15, 2020, 11:34:45 PM
I’ve used the same design to make the LED module removable...
au Offline Huntsman
Reply #77 on: April 16, 2020, 01:58:20 AM
That's neat Max -  :like:    :tu:
Reply #78 on: April 16, 2020, 10:03:01 AM
Thanks for pointing out the feature on the Rescue Tool. It was the last piece of the puzzle I needed for this mod. If I was equipped for metal fabrication, I’d build a long flat driver that could clip on the pivot and drop below the Phillips, a bit like the 111mm design.  :think:
id Offline jaya_man
Reply #79 on: April 21, 2020, 03:39:09 AM
No worries Max... The Rescue Tool isn’t the only one with that feature... The removable USB flash drives in 58mm models use the same too... Unfortunately I don’t have a pic as I never owned one let alone dismantle one... a friend told me this while doing his 58mm mod...
00 Offline NeleDo
Reply #80 on: April 21, 2020, 01:59:15 PM
Nice and very useful mod!  :like:
Reply #81 on: April 21, 2020, 06:29:03 PM
Apologies
And we let you manage the Wiki...
 :facepalm:  :twak: :twak: :twak: :twak:
 :D :D :D :D
Reply #82 on: April 21, 2020, 06:31:17 PM
Brilliant!
 :tu: :tu:
au Offline Huntsman
Reply #83 on: April 22, 2020, 09:59:56 AM
 :D :D :D :D
This is indeed worrying - I think a resignation is in order !
pt Offline FInixNOver
Reply #84 on: April 22, 2020, 11:39:17 AM
True!
I'll see if I can find pictures of when I modded mine.
Enviado do meu Redmi Note 5 através do Tapatalk
Reply #85 on: April 22, 2020, 01:20:22 PM
You wish! You'll be doing that until you know everything about SAKs! That's your punishment!
 :twak: :twak:
id Offline jaya_man
Reply #86 on: May 06, 2020, 01:09:05 AM
Forgot I had this...
Cadet II X mod
id Offline jaya_man
Reply #87 on: May 06, 2020, 01:12:25 AM
Victorinox Climber Small
Reply #88 on: May 06, 2020, 09:44:34 PM
That looks like a nice example jaya_man  :like:
Are you restoring it?
id Offline jaya_man
Reply #89 on: May 07, 2020, 01:06:52 PM
The climber small isn’t mine... it belongs to a friend... The scissors layer was used for the Ti Compact Tinker Small mod I did recently...
The Cadet II X was a mod I did a while back... I intend to dismantle it again and add an inline phillips to it... that is if I can find an appropriate donor... :cheers:
March Goal: $300.00
Due Date: Mar 31
Total Receipts: $136.50
PayPal Fees: $7.22
Net Balance: $129.28
Below Goal: $170.72
43%
March Donations
