Welcome CathalAll good points above. Good luck and enjoy that surge!
Welcome aboard! Up to a good start, I see. Thunda pretty much said it all. Keep using it and getting used to it. Browse the forum (use the search box at the top) and you'll probably find some answers, along with some pics and instructions.
For plier pivot, I do a little different from most people.. I actually degrease it. I do it with a degreaser/contact cleaner spray. Then I will keep on opening and closing it a couple of hundred times, the feeling will get more gritty, more friction, even better and I will keep going. Bare metal against bare metal will wear faster. To me, at this stage using any kind of oil would be counter-productive. It would slow down the wearing. When i think I am happy with it, I would spray flood the pivot with contact cleaner again to flush out the gritty stuffs. If needed, I will do everything all over again. Oil only when I am satisfied with the result.BTW, theres no serrated blade with gut hook for surge..
Welcome to MTO, from a fellow paddy!
the accent is different
Welcome!The best advice I can give you, if you want to break your Surge, is to lend it to Pablo for a few days. edit: Just re-read the question. Never mind the above. A little oil, a little use, and the action will slick up.
I had/have a Surge that was super stiff when I first got it. I though it would loosen up with use and I have used it fairly hard. Never loosen up especial the ends with the internal tools/drivers. I finally broke down and got myself two security torque bits and loosened the pivots up just a bit. It made a HUGE difference to how usable the tool it. Being able to quickly and easy get the tool out I need is great. I would not hesitate to do the same again with my next tool. Suffering with a hard to use tool sucks!
