Login
Register
Menu
Home
Help
Forum
Tool Talk
The Mod Squad
how to get wave pivot out?
kingofswords
6 ·
412
« previous
next »
Print
Pages:
1
Go Down
kingofswords
Sr. Member
349
on:
April 05, 2019, 02:43:22 AM
how do i get it out? ive unscrewed it but but pivot is stuck.
do i have to get flat edge lined up?
sawman
Absolutely No Life Club
9,745
You're amongst friends.
Re: how to get wave pivot out?
Reply #1 on:
April 05, 2019, 03:17:46 AM
I'm not entirely sure but with gerber multipliers I make sure to slide the lock forward to take any tension off and if needed gently tap the pivot thru or gently pull & twist from the other side if you can without damaging the pivot head.
SAW
Sam Lim
No Life Club
2,306
Reply #2 on:
April 05, 2019, 06:43:15 AM
Quote from: kingofswords on April 05, 2019, 02:43:22 AM
When u say stuck, does the post screw spin on the spot or it doesn't turn at all?
Merit Badges
pietervn
No Life Club
1,712
Reply #3 on:
April 05, 2019, 09:36:50 AM
Which side? Pliers or Tools?
Merit Badges
kingofswords
Sr. Member
349
Reply #4 on:
April 05, 2019, 01:35:30 PM
tool side
no it doesnt spin but i forced it with screwdriver and it eventually came out
so now worried i might of broke the tab bits that rest on the flat side of the pivot which stops it rotating when in use. .
McStitchy
Global Moderator
Zombie Apprentice
19,785
Reply #5 on:
April 05, 2019, 03:05:07 PM
I guess what happened there was that the pivot was turned while loosening the screws and it got jammed out of the notch that is supposed to prevent that.
It can happen easily, I never remember which side to turn and which not.
It shouldn't cause you any problems. Make sure to use Loctite though when re-assembling.
Merit Badges
Print
Pages:
1
Go Up
Forum
Tool Talk
The Mod Squad
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$168.99
PayPal Fees:
$9.87
Net Balance:
$159.12
Below Goal:
$140.88
Site Currency:
USD
53%
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
