Quote from: cgjones on December 23, 2008, 10:14:38 PMQuote from: Benner on December 23, 2008, 09:58:09 PMOh, and sorry as well. I really hope it doesn't bug you like it does me. It's nice to hear yours are the same though. It doesn't bug me at all. You're obviously not a saddo like me then.
Shame that "most" doesn't include you.
Ben don't forget to bring it to the meetup mate then we can all have a look at the play . My Atlantic Salt won't be there as I given it to the Lifeboat and it now stays onboard the boat . But I will bring my UKPK .Dunc
None of my spydies have any play, lock up in both directions are solid. I heard the new Endura 4 have an issue with slight vertical play. If your knife is new you might be able to send it back to spyderco for a replacement. Spyderco is pretty good with warranty. No quality folder should have any up/down play in the blade, it may compromise the locking mechanism. I saw a youtube vid where a guy had a endura and the lock completely failed , he could close the blade without disengaging the lock.
Quote from: Nutznboltz on December 28, 2008, 05:30:06 AMNone of my spydies have any play, lock up in both directions are solid. I heard the new Endura 4 have an issue with slight vertical play. If your knife is new you might be able to send it back to spyderco for a replacement. Spyderco is pretty good with warranty. No quality folder should have any up/down play in the blade, it may compromise the locking mechanism. I saw a youtube vid where a guy had a endura and the lock completely failed , he could close the blade without disengaging the lock. Is it the guy smacking the handle from under with a stick? He's an idiot for doing it and completely broke the locking notch on the blade off. The way spyderco designed the backlock it's more secure but normal to have small amount of up/down play
