A bit of my own opinions on the two:
While somewhat similar, the uses of the two differ by quite a bit. The SPOT is an excellent utility knife...the belly/recurve makes chopping/slicing a breeze, but other than that, the blade can't do much. The hawksbill is not pronounced/long enough, thus it can't cut what other hawksbill can. The LaGriffe on the otherhand was designed for slashling and a bit of thrusting. Slicing up things are a breeze, but really, without some sort of belly, it's limited to 'rip' cuts.
All in all, both are solid knives, and both have vastly different uses.
Brendan
