Login
Register
Menu
Home
Help
Forum
Tool Talk
Swiss Army Knights Forum
Looking for slimmest scissors and saw
Tarheelpwr
13 ·
585
« previous
next »
Print
Pages:
1
Go Down
Tarheelpwr
Full Member
125
on:
May 25, 2019, 03:59:23 AM
I’m very new to SAK - been mostly a plier based MT guy. But, I’m looking for a scissor and saw to compliment my EDC center drive.
I see the huntsman, but that has LOTS of stuff i. Don’t need. Is there anything smaller?
Can someone make me a 2 layer tool with the scissors and saw? I wouldn’t mind both metal and wood saws if I had to add somethings.
Blackbeard
No Life Club
3,309
One Day Closer To Death
Re: Looking for slimmest scissors and saw
Reply #1 on:
May 25, 2019, 04:47:41 AM
maybe an older discontinued model has that configuration, but I don't think there is one now, huntsman or the evolution 18 version are probably the "smallest"
The evo has no hook, but is probably about same width as huntsman.
BB
Merit Badges
nate j
No Life Club
3,552
Reply #2 on:
May 25, 2019, 04:56:35 AM
Welcome to the world of SAK!
With regard to current production models with both scissors and saw, I'm afraid a four-layer knife (Huntsman, Fieldmaster, Evo 17, or Evo 18) is as small as it gets.
The saw takes a full layer (typically with no back spring tool). The scissors also take a full layer (typically with hook on the back spring). I don't see any technical reason why a two-layer mod consisting of just these two layers could not be done.
Other mod options might include Compact + saw, or Huntsman (or similar) - opener layer, either of which would be a three-layer mod.
FWIW, I find the Huntsman (or equivalents) to be easy pocket carry, though not everyone agrees.
Merit Badges
Huntsman
Global Moderator
No Life Club
4,574
Reply #3 on:
May 25, 2019, 07:35:29 AM
^^^^ Yep - That is the story
However - As my name might suggest - I can thoroughly recommend the Hunstman - I carried one for decades
Depending on your needs - You may even find you could carry a Huntsman (or a Fieldmaster) instead of the Centre Drive, on days when you don't need pliers/heavy duty ?
Else a Mod ...... Compact + Saw would be pretty good !! Or even highly customised 2 layer Saw + Scissors mod!!
One of the US modders could knock one up for you - You could even try yourself - See the modding guides in the Mod Forum
Last Edit: May 25, 2019, 08:17:10 AM by Huntsman
Merit Badges
Max Stone
Absolutely No Life Club
5,980
Reply #4 on:
May 25, 2019, 10:11:41 AM
Other than a custom mod, you could look at the 85mm Evolution range. The scissors/saw combo is a little thinner than the Huntsman.
(Filesize: 176.3 KB)
Merit Badges
kamakiri
No Life Club
3,215
Reply #5 on:
May 25, 2019, 06:33:10 PM
A Marlboro - The Trail Guide has Scissors the Metal Saw. ...Which I find cuts wood okay. Better with hardwoods than anything green. I would like this model better if it came with a back Phillips instead.
A mod with just just the scissors and wood saw would have a blank spot in the back that might bother some. Might look least goofy with the scissor/hook version on that side, but the spring would be partly exposed.
Merit Badges
kamakiri
No Life Club
3,215
Reply #6 on:
May 25, 2019, 06:37:24 PM
And the mod wouldn't have a keyring. Or I can't think of a way to incorporate a factory looking one, unless it's a shackle type.
Merit Badges
Sawl Goodman
Hero Member
915
Between this & that.
Reply #7 on:
May 26, 2019, 03:03:24 AM
If you want to follow the mod route, how about taking a Ranger and removing the blade and opener layers? Keep the associated back side tools and you'd have a nice multitool a little thinner than a Camper - and you'd have parts for a Spartan left over.
Rambler
Max Stone
5,980
Reply #8 on:
May 26, 2019, 10:29:37 AM
There's still no easy way around the ugliness of the scale gap where the corkscrew won't be when removing the blade layer. If you can't live with a Huntsman, I'd take the saw from a Camper and add it to the Compact as you get to keep the lanyard loop which is in a different location already on the Compact. The Camper can be rebuilt to a Spartan and the Compact basically becomes a Trail Guide with a wood saw instead of a file. You would still need new brass rod to build out the Camper another layer. Alternatively, just ditch the opener layer of a Huntsman and reuse the brass pins as there should be enough length left. But then there's no lanyard loop.
Merit Badges
Max Stone
5,980
Reply #9 on:
May 26, 2019, 10:40:23 AM
Layer comparison:
Handyman (6)
Ranger (5)
Huntsman (4)
Camper (3)
Compact (2)
(Filesize: 224.73 KB)
Merit Badges
Don Pablo
Zombie Apprentice
15,292
Yoo-hoo, big summer blowout!
Reply #10 on:
May 26, 2019, 10:43:13 AM
FYI: you can put the saw in the blade layer, instead of the blades, and keeping the corkscrew!
You just need to make a spacer on the keyring end to fill the empty spot and provide a place for the sawtip to rest on when closed.
Hooked, like everyone else.
Merit Badges
Don Pablo
Zombie Apprentice
15,292
Reply #11 on:
May 26, 2019, 10:45:13 AM
Here's the way jaya_man did it, but it's not the only way:
https://forum.multitool.org/index.php/topic,68332.0.html
Merit Badges
Max Stone
5,980
Reply #12 on:
May 26, 2019, 11:07:55 AM
That's a great idea DP...especially if you can use the Compact as the base and you then get the saw, scissors and retain the corkscrew in a 2-layer SAK...but it would need some spacers on the other end.
This does seem to be the best solution for this request!
Merit Badges
Print
Pages:
1
Go Up
Forum
Tool Talk
March Goal:
$300.00
Due Date:
Mar 31
Total Receipts:
$379.86
PayPal Fees:
$19.62
Net Balance:
$360.24
Above Goal:
$60.24
Site Currency:
USD
120%
March Donations
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
