Wear on bushings in tool holes
gb Offline craggus2000
on: June 11, 2019, 04:39:08 PM
For those that have had to reduce holes in tools when modding…
How do you find the bushings perform over time? Do they wear and make a larger hole? The threads I've seen here talk about using brass to fill the holes in the tools and then redrill with a smaller hole, which is what I'm considering on my next SAK mod - Filling a 4mm hole in a main blade and then redrilling with a 2.5mm bit.
By all accounts should it be reliable long term?
Thanks as always!
« Last Edit: June 11, 2019, 06:39:46 PM by craggus2000 »
Craggus2000
"If it ain't broke, break it and make it better!
Offline James Downey
Re: Wear on bushings in tool holes
Reply #1 on: December 27, 2019, 05:19:53 AM
I'm going to dredge this one up because I was wondering the same thing.
