Victorinox SwissTool Black Oxidized Multi-Tool / leather sheath - $48 to USA
us Offline eodtech
Victorinox Swiss Army SwissTool Black Oxidized Multi-Tool  (Item model number: 53954)  $48 delivered to USA  ( 70% OFF MSRP )
    * Multitool is 4.5 inches closed, 6 inches open; 10 ounces; Lifetime warranty
    * All blades and implements lock for safety and convenience; oxidized black
    * Includes 27-function multitool and LEATHER Pouch
    * Stores comfortably in leather case or hangs from neck via lanyard hole
    * 100% stainless-steel construction protects tool from rust or decay
Product Description
From the renowned company that created the Swiss Army knife a century ago comes this folding tool kit--neatly contained within a single implement that measures just 4-1/2 inches long and 1-1/3 inches thick, weighs just 10 ounces, and comes in a leather belt pouch. Its rugged stainless-steel construction and ease of use make this tool kit is a tribute to the precision of Swiss engineering. Tools open individually (no clumping), lock in place, and fold with a push button. The SwissTool carries a lifetime warranty against defects. The tools include pliers; 2-, 3-, 5-, and 7-1/2-mm screwdrivers; Phillips head screwdriver; wire cutter; bottle opener; large knife blade; serrated blade; metal file; metal saw; wood saw; reamer/punch; chisel/scraper; crate opener; wire bender; wire stripper; wire scraper; can opener; 9-inch ruler; 230-cm ruler; electrical crimper; and lanyard hole.
Product Description
Pliers Screwdriver (2mm) Screwdriver (3mm) Wire cutter (for wire up to a hardness of 40 hrc) Screwdriver (5mm) Bottle opener Screwdriver (7.5 mm) Large blade Serrated blade Metal file Metal saw Wood saw Reamer/punch Phillips screwdriver Chisel/scraper Strong crate opener Wire bender Wire stripper Wire scraper Wire crimper Can opener Ruler (9 inches) Ruler (230mm) Hard wire cutter Lanyard hole Easy kickback springs Lock release Black Oxidized Comes with leather belt pouch
Why do I carry a 45 ?
June Goal: $300.00
Due Date: Jun 30
Total Receipts: $139.46
PayPal Fees: $8.05
Net Balance: $131.41
Below Goal: $168.59
44%
June Donations
