Thank you very much, Pabs! Definitely worth getting back into rechargeable batteries again. My only experience with them is limited to the rechargeable NiCd and rechargeable alkaline batteries from the 90s(which weren't great and got set aside when they couldn't run my digital camera and other modern high-drain devices). Will be nice to try the NiMH, with Eneloops.
I think the eneloop is light years ahead of good old nicd or even most nimh cells, they don't have as much 'memory' problem, and no need to empty to charge everytime. If you are into rechargeable, they are really nice to get.Personally, I am just a really forgetful person, and it's hard to keep track what needs to get charged or not. So most of my AAA/AA remotes/appliances I use Lithium AA/AAA, but for stuff I use very frequently and track everyday(like my wireless keyboard/mouse), I think eneloops are the way to go.
I don't trust anything, I lost a ThruNite T10s flashlight to an Eneloop that spilled its guts inside it. If you wanna store it for a longer time, lithium or lithium ion from reputable brands. Otherwise, store separatly
Kinda surprised Eneloops leaking . I've had some Eneloops sitting in lights for a while with no issues. I also make sure to unscrew the heads slightly so no accidental activation while sitting. Thanks for the heads up tho, Ill keep an eye on those lights. I have Surefire Lithium and Panasonic as well as Olight 14500s rechargeable. I run the 14500s in my Zebralight SC52L2.
Interesting. I've never had an eneloop leak. Sent from my G8441 using Tapatalk
I know it's been a while ...But I just found it. I thought I threw it away, I knew I kept it for some time as a reminder and as I wanted to take pics of the leak, but couldn't find it ... till now. The culprit, the leaky eneloop lite. I know I've had it for years, and the rest of the pack it came with are still going strong in other devices and flashlights, but this one ... ... leaked. And not like alkalines leak, this one just seems like it got wet, hardly if any corrosion, no build up on either the flashlight it ruined or itself.
That's the first time I've seen an original generation Lite! 50-70% of my age...
I was unaware that Lite in the AA version existed (so far only seen in the AAA version) Searching the web I found them, they are AA with a capacity of 950 mA and have 3000 guaranteed cycles.This official link could perhaps help ..https://www.panasonic-eneloop.eu/en/faq/what-could-cause-leakage-ni-mh-rechargeable-batteries
Ha? These were bought in 2012. That would make you 10-14 years old....
I must be a high capacity battery...I also often leak.
My Sidewinder wouldn't work last night; and it had been a little fussy for about the past week. Had been using the light every night. Noticed the negative terminal of one of the AAs had corroded (not leaked!). Battery was a couple months old ,and had been in the light a month or less. Hard to believe a Duracell would do it. Maybe it explains why Maglite has changed from Duracell to Rayovac in terms of the batteries they pack with the lights. I put in Energizers this time.
I had removed the batteries from electronics that do not get used often, but a flashlight escaped. The battery had corroded, but the flashlight still works. Check your stuff, and remove batteries from them and store them separately if you don't use them often.
