Great job! Ive been wanting to try this for a long time but have always chickened out. I definitely agree that victorinox is missing a trick here not offering this as a factory model.Are the pins you used nickel silver or solid brass? Is that a hand drill in the second photo? How did you find removing the stock pins without a drill press?
Also how is this still not a vic product!?
Have you got a Dremel or something similar? You can use a diamond ball bit to remove the pin head easily enough and then just punch out the remainder of the pin out.
I think it depends, I tried the small 2mm ball dremel method, and was having serious run out issue. I actually prefer drill hole, dremel then punch out.
Well... excuuuuuuuuussssseee me! (Steve Martin voice)
You and Comis are 2 wild and crazy guys!!!!(Image removed from quote.)
Serious though, you probably are way better at dremel than me...
Thanks everyone!Also requested the Hacker badge for this topic
Awarded.
Wow, and congrats! I didn't realize this was your first mod? ...or just your first request?
First mod
Then that's a huge achievement! Working right the first time with an afternoon build...nothing smurfed up on disassembly...or needing to re-do... Somehow, I thought you've been doing this for years and this was maybe your first 93mm.
I feel flattered
Even later to this party than Fuzzbucket Great job Mechy I've always held off on peening 93mm SAKs because I have the lathe handy, but it's good to know it can be done with some hammer skill and mediocre patience.
