Best to avoid oil and first get the dirt out. A good several-hour soak in warm water with detergent and then agitation to dislodge the grit will do wonders at recovering the ‘snap’ of the tools. Gentle dry and very light oiling at the pivots. If you have access to an ultrasonic cleaner, happy days
Use the Vic oil on my saks as well, can get a small bottle on ebay from seller Belote for pretty cheap.
How do you agitate it? Just shake it around in the water for a minute?
Thanks for this. Just bought a bottle dirt cheap. 3 in 1 works great on all my knives, but I was wanting to try this on my Vics.
I agree with comments about cleaning first.Really like Hoppe's No. 9 gun oil.
I'm a Hoppe's man also. I love the small bottles with the precision tips. My ritual for cleaning dirty SAK's is to soak them in a basin of warm water and Dawn dishwashing liquid, and then using a toothbrush to remove the gunk.I use paper towels and cotton swabs afterward, to remove moisture and any grime that's left over. A few shots with some canned air is also helpful. Lastly, the Hobbes gun oil is used to lube the joints.
I use mineral oil on SAKs that will eventually see food.
...but I love the Hobbe's precision oiling tip too much to give up.
Are any of you concerned about residual water/soap remaining under the scales, in the toothpick and tweezers slots? I just wonder if any remaining water can cause corrosion or rust after a rinse.
