Leatherman Charge Plus TTI - cap crimper
MrVic · 16 · 1442
Offline MrVic
on: July 30, 2019, 01:28:55 AM
I’m curious about the Charge Plus TTI
Has anyone found any use for the cap crimpers on this MT, other than crimping detonation fuses?
Seems strange that LM put the crimpers on a non speSmurfpillst MT like the Charge. But has anyone found any other uses for the crimpers.
Also, has anyone found the crimpers to either weaken the pliers or otherwise impede their primary function?
Cheers
 :multi:
us Offline JonesE
Re: Leatherman Charge Plus TTI - cap crimper
Reply #1 on: July 30, 2019, 02:03:05 AM
Hi MrVic, I truly have not noticed any weakness in the pliers jaws of either my standard Charge TTi or my Charge Plus TTi. My uses are more along the lines of around the shop and EDC.
JonesE
Offline MrVic
Reply #2 on: July 30, 2019, 02:18:39 AM
JonesE
Thanks JonesE. Have you found any use for the cap crimpers?
Cheers
Omar
us Offline JonesE
Reply #3 on: July 30, 2019, 02:23:03 AM
I think once or twice I may have installed some terminals on some wires. I honestly forget the crimpers are there.  :facepalm:
JonesE
us Offline genevabuck
Reply #4 on: July 30, 2019, 02:47:00 AM
They are great for crimping small lead sinkers when fishing. I also use it for cracking open pistachios that are only slightly split open.
Offline MrVic
Reply #5 on: July 30, 2019, 05:56:45 AM
JonesE
So there’s some other possible uses.. :multi:
Offline MrVic
Reply #6 on: July 30, 2019, 05:57:15 AM
Hahah never saw that coming! :)
Reply #7 on: July 30, 2019, 06:09:28 AM
I did not like them at all.  I had no reason other than I had no use for them and I also thought they might weaken the plier.  I have had any issued on my TTi but I've also not found any good use for them either.  They are not in the way nor hamper my use.  It would be nice however to use them at some point  :D
Offline MrVic
Reply #8 on: July 30, 2019, 11:51:48 AM
Thanks Aloha. The TTI tempts me, but I probably shouldn’t. Have a Charge Plus, which I got mainly because the crimpers put me off the TTI..
Reply #9 on: July 30, 2019, 02:37:18 PM
If you are interested in Titanium but no cap crimpers you could locate a Ti ( older version ).  It has 154CM main blade and no gut hook.  Just a thought.
Reply #10 on: July 30, 2019, 02:59:39 PM
 :iagree: :cheers:
Offline MrVic
Reply #11 on: July 30, 2019, 09:30:58 PM
It was more the S30V blade that was interesting me. I seem to be doing a good job of convincing myself I need it (I don’t). I like the replaceable wire cutters (not that I’ve had to replace any yet!).
Am I just spending too much time on MTO???  :facepalm:
za Offline Max Stone
Reply #12 on: July 30, 2019, 09:46:25 PM
Really nothing wrong with 154CM if you’re looking for better the stock garden-variety 420. Recently picked up the older Ti with the 154CM blade and can highly recommend it.
Reply #13 on: July 30, 2019, 10:17:24 PM
That's the one  :tu:
Of course you "need" a TTi or Ti  :pok: especially since you don't have one.  Replaceable cutters  :dunno: thats where I am not certain I "need" the upgrade from my TTi and Ti.
nl Offline EMZ
Reply #14 on: August 15, 2019, 06:09:40 PM
Cheers
 :multi:
NO.
Okay, here's some explanation. I love the CC because I once -for a very short time- was doing some work in Special FX. In that line of work you really need a good multi-tool. Most of the time my SwissChamp saved my day.
When the TTi with CC came out, I already stopped doing SFX for a long time, but I still love the CC as a sort of personal nostalgic remembrance.
us Offline Outback in Idaho
Reply #15 on: August 15, 2019, 06:37:57 PM
  The lead sinker crimper takes up too much real estate on the pliers, v1.0 or v.2.0 it's a waste of space. Can pull nails out with it, or... succumb to the dark side of the force...
  (Not my work, but sharing is caring)
* ReCharge TTi.jpg (Filesize: 55.17 KB)
¬ Outback in Idaho
