The closest "reasonably inexpensive" blade option I can think of would be the one on the Paul Chen Professional MT. Both have similar liner setups and thumbstuds.
Now, that said, I do not know if the pivot and lock position would work out. Maybe one of our resident modders might know?
If I had a user A100, I'd remove the blade and find out, but at the moment the only one I have is NIB.
Edit:
Looking at both of the blade setups, the Chen Pro blade would need notable grinding to match the A100 tang anyway, so that is a no-go. The studs also aren't positioned in the same place, meaning the A100 would need to be notched out further to accommodate the Chen blade.
« Last Edit: August 04, 2019, 08:43:16 AM by gerleatherberman »
