Bringing a post back from the dead. For those that have added a Honeybee blade with 2 springs. How did you eliminate blade play? I tried using a small brass washers and it kept interfering with the spring and kept my blade from staying closed. Thoughts would be great!
Hey mate, I was actually just thinking about posting my new mods here recently after so long away from the forums!
Sounds like the washers you are using arent small enough. they need to stay completely out of the way of the back spring.
I used to used 2/32 washers from knifekits which were too large but because the hole was also too large it kind of pushed up and kept out of the way.
The best solution, and what I do now, is make my own washers that are 4mm in diameter and have a 1.7mm hole.
If you want photos let me know.
