Do you think Leatherman will replace this???
Offline Thatperson
on: September 21, 2019, 06:33:14 PM
I have this super old wave that belongs to my dad and he's had it for the longest time. He doesn't use it anymore because he uses a newer version of the wave. It has a total of three completely broken tools and the pliers are broken from one of the tips at the end. The blade also has a broken tip as well. It's just so well used I'm not I'm not sure if Leatherman will replace it. Would it be a good idea to send it in?
* IMG_20190921_112616_compress12.jpg (Filesize: 45.84 KB)
* IMG_20190921_112646_compress56.jpg (Filesize: 44.75 KB)
* IMG_20190921_112716_compress88.jpg (Filesize: 44.34 KB)
se Offline RF52
Re: Do you think Leatherman will replace this???
Reply #1 on: September 21, 2019, 06:35:47 PM
I think they will fix/replace it :tu:
Reply #2 on: September 21, 2019, 06:40:07 PM
I'm sure the will replace it with the new Wave however if you want this tool back make sure to make to paperwork sentimental.  Good luck.
Reply #3 on: September 21, 2019, 06:45:54 PM
They will take care of you with it :cheers:
Reply #4 on: September 24, 2019, 04:27:18 PM
Yes. Leatherman has an outstanding warranty and they will attempt to repair it and return it to you if you tell them it has sentimental value and you want it back. If you're not sentimental about it and you just tell them you want it fixed they will just send you a new Wave to replace it.
Total Receipts: $36.34
PayPal Fees: $1.66
Net Balance: $34.68
Below Goal: $265.32
 12%
