I still stand behind the glass drilling carbide coated harbor freight bits as the cheapest and quickest method.You have one more issue now that you've burned up some cobalts bits in the drilling attempts. The metal is hardened(work hardening) a bit more than it was when you started. The contractor bit might have worked before, but you'll need carbide or diamond to get through that sucker now.I still use the same set of carbides that I had bought originally, and they still work. I do use a drill press on slow and oil to drill through. Patience and a hand drill should work well too.Haven't tried water, and probably won't as long as I have oil/penetrating fluid available.The hardest metal I've drilled through was 420HC. I don't know how the cheap bits would work with anything harder yet.Only downside of the HF carbide coated bits is that the size options are limited.Best of luck, KG!
WOW!!! I never should have doubted you. I went to Harbor Freight, bought 2 different sets of masonry bits, and the carbide glass bits you suggested. As you mentioned, they dont have a lot of sizes to choose from. I needed 5/32, and the glass bits were only 1/8 and 3/16 and larger. So I started with a 5/32 masonry bit. It chewed in but stopped digging after a bit. (so close ) So I put the 1/8 glass bit on and it dug right in. Slowly but surely, I got all the way through. After I had a hole, the 5/32 masonry bit was just strong enough to widen the hole to the right diameter. (but it was a struggle) I am so surprised that after everything I have messed with, it was a glass bit made it through hardened knife steel! Thanks again, gerleatherberman If you come to Vegas anytime soon I'll buy you a drink.
Late to the party but yes, glass/tile bit work very well, I used one on a diamond file mod.I found the quad tip type to be extremely effective.
grind away the sides carefully until you hit the exact width.
I have to drill out sak tools for pivots and I use the dremel tungsten carbide cutter #9903. It cuts through the steel no problem you just have to manage the heat.
