USB rechargeable flashlights for 2019 262
Zombie Apprentice Posts: 19,740 Oxygen and magnesium toghether?! OMg!
« on: October 29, 2019, 01:38:31 PM »
Here's something I found, you might like it:
https://www.youtube.com/watch?v=ct2Fu2EP5yQ
Hero Member Posts: 910 Did you know Uranus has 22 moons?!?
Re: USB rechargeable flashlights for 2019
« Reply #1 on: October 29, 2019, 06:33:07 PM »
Thanks! I have a Nitecore TUP and my favorite, my Thrunite T1 that are rechargeable. It is a nice option to have. The advantage to these...like my T1 is that they have a removable battery so you can also have another battery topped off if the situation calls for an immediate change out.
Rather mundane quote entered here to approximate humor.
Absolutely No Life Club Posts: 6,070
« Reply #2 on: October 29, 2019, 06:53:58 PM »
Thanks for sharing.
I usually prefer using rechargeable batteries rather than built in recharging, so that if needed I can swap the battery and still use the light rather than wait for it to recharge, especially now with such small portable rechargers.
I did have to look a couple of them up.  The Fenix PD36R and Jetbeam KO-02 look most interesting to me.
While in the Navy, I carried and used a Fenix light for several years.  It took a lot of abuse and never let me down, so I trust them.  I also like that the 21700 battery is a standard battery that could be replaced or also charged outside the light.
The Jetbeam light not only uses a standard 21700 battery, but is also compatible with other standard batteries like 18650 of which I have several.
The Skillhunt light sounds good with the capability to accept AA as well, but I am skeptical with its claim of 750 lumen.
« Reply #3 on: October 29, 2019, 10:56:08 PM »
I ordered and received a NekTeck 21W solar charger and a Basen 2 port smart charger. The charger can plug into the wall or charge via mini usb so that I can run it off my solar panel. Another advantage is that the charger has a usb output port so in a pinch, I can use my charged flashlight batteries to charge my phone. This setup should allow me to keep the lights on through the night when camping. I usually keep my phone off unless needed, but it will allow me to charge it in emergencies.
Total Receipts: $168.70
PayPal Fees: $9.84
Net Balance: $158.86
Below Goal: $141.14
53%
Page created in 0.032 seconds with 33 queries.
© 2018 Defender Web & Tool
