Thanks, guys. Read an article and actually I do have and use Lansky kit, however the result is far from perfect if you look at it since I can’t find the proper angle. LMs are sharpened at 16 degrees per side if I’m not mistaken, so it’d be 32 degrees. Lansky kit only has 30 or less. It was not a problem reproducing a plain edge, but serrations do need some totally different approach and practice as far as I can tell
