Login
Register
Menu
Home
Help
Forum
Tool Talk
The Mod Squad
Explorer like SAK mode with small blade only
BePrepared
11 ·
1700
« previous
next »
Print
Pages:
1
Go Down
BePrepared
Sr. Member
418
on:
November 09, 2019, 09:00:42 PM
This is my first SAK mode and I made this: 3 layers, 76g, only small blade
I used a second hand Swiss Champ for parts
I started drilling out the brass pivots
I did make progress
But it was very slow work, and when I tried to prise off the bushing I was damaging the overhang lip on the bushing
So I gave up on that approach and used the Dremel to grind off the bushing
Here are the selected parts from the Swiss Champ, that I planned to rebuild into something new
The small blade spacer is a little too wide, and the backspring for the small blade and cap lifter is a little narrow for both tools. It does work, but the cap lifter sometimes returns to closed position and hits the blade. I don't feel this is a big problem. The nail nick on the small blade is a little low, I I can still open the blade. YMMV.
I made my own bushings to replace the ones I destroyed. I had some brass tubing that I sliced up. I didn't have the best fitting sizes, but it worked.
I got some 91mm 3D printed sclaes from internet, and aksed seller to invert the design for the top scale and print it for the opposite side.
Merit Badges
tommywp
Hero Member
506
Re: Explorer like SAK mode with small blade only
Reply #1 on:
November 09, 2019, 09:14:14 PM
Good work.
Which back spring did you use for the small blade and lifter, and what made you choose that one? Could you share a link for those scales?
comis
Zombie Apprentice
11,394
Reply #2 on:
November 09, 2019, 10:11:28 PM
Great mod!
I love the small blade on the 91mm, found myself using that most majority of the times
Same questions as Tommy.
Comis Gear Youtube Channel
Merit Badges
BePrepared
Sr. Member
418
Reply #3 on:
November 09, 2019, 10:19:21 PM
As in the pic showing the exploded layers view, I used the cap lifter/can opener back spring for the cap lifter and small blade. The backspring is probably a fraction too thin for a perfect fit, especially if you add the small blade spacer. But if you don't add the spacer the small blade and cap lifter share too much of the same space. Even with my solution, the cap lifter sometimes comes down on top of the small blade, and I have to push the cap lifter sideways for it to fully close. It's a tight squeeze in there! The nail nick is also low on the main blade, but I can still pull out the small blade --- in a way, it's nice the small blade is hidden away as it might this EDC friendlier.
From whet I've learnt from those with more experience than me on the Forums, is that SAK back springs and tools don't mix and match easily. I kept the cap lifter backspring, because it gives a half-stop to the cap lifter (and I'm not sure any other back spring from the Swiss champ would work anyway.)
Not sure if I am allowed to give out the link, but if you search "etsy victorinox scales 3d printed" you will see some sellers. I bet most of those who 3d print could flip the pattern for the top scale to make a mirror image for the bottom scale, without cut out.
The most interesting thing Iearnt, is that it's possible to make crude bushings from brass tubing, and these seem to do the job just as well as the originals (which are difficult to salvage when taking apart the donar SAK).
Merit Badges
BePrepared
Sr. Member
418
Reply #4 on:
November 16, 2019, 06:21:42 PM
I did some mroe work this weekend. I took apart an old explorer, and used a set of bushings from that for this build since I had destroyed one set when I made this. I also gouged out a slot on the 3D printed scales for a pen --- plus scales!
One problem is that the liner I used for the outher scissor layer does not hold in the pen.
I only realised the problem after I repeened the pins, so I'm not changing it now. The pen and scissors play OK together. The scissors just pushes the pen back into the groove in the scales. Next time I'll know better,or put the pen on the other scale.
Merit Badges
jph_777
Full Member
116
Reply #5 on:
November 16, 2019, 11:05:34 PM
Good Mod BePrepared! Nice photos too. Thanks for sharing.
pomsbz
No Life Club
2,595
Reply #6 on:
December 02, 2019, 02:32:23 AM
Can you provide a link for the scales please?
Merit Badges
SirVicaLot
Absolutely No Life Club
5,979
Reply #7 on:
December 02, 2019, 02:40:55 AM
You can find these on Etsy. Search for the store „Taschenmesser“
Merit Badges
Sos24
Global Moderator
Zombie Apprentice
11,180
Reply #8 on:
December 02, 2019, 02:53:07 AM
Nice mod. A lot like the Yeoman, which is my favorite SAK. I can see where that would be very useful.
Merit Badges
pomsbz
No Life Club
2,595
Reply #9 on:
December 02, 2019, 03:20:33 AM
Quote from: SirVicaLot on December 02, 2019, 02:40:55 AM
Thanks!
Merit Badges
Aloha
Global Moderator
Point Of No Return
31,235
Reply #10 on:
December 02, 2019, 11:38:49 AM
Nice mod. I also have a heck of a time salvaging those bushings.
Merit Badges
Print
Pages:
1
Go Up
Forum
Tool Talk
The Mod Squad
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$115.65
PayPal Fees:
$7.03
Net Balance:
$108.62
Below Goal:
$191.38
Site Currency:
USD
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
