Well, what to say, the result with the spring justified the first expectations, although I will still test, I hope in the continued operation of the blade and spring remarks will not be revealed, clicks softly, the tension is slightly weaker than the factory, the part with the reamer is completely eliminated in this assembly, for whom it is critical, keep it in mind.. Blade from Elmax steel
