Hi, WrenchHeadFox.Thanks for your extremely in-depth analysis! As for your two questions at the end:It's easy to tell nylon from celidor. Celidor scales are smooth, shiny and have a metal inlaid logo. Nylon scales have a rough matte surface and a hot-stamped logo.Unfortunately Celidor scales inevitably warp when exposed to hot temperatures. Is there a way to dye them cold?
Very happy to help, Don Pablo. That's unfortunate about the warping, but not a shock to me. Do you happen to know what temperature the warping occurs? Natural fibers (hemp, cotton, jute, etc) use a "cold dyeing" process, but that's kinda a misnomer. Yeah, it's colder than a boiling vat, but it's still around 160 degrees F... well above temperatures you want to stick your hand in. The temperature aspect is critical to the disperse dyeing process, as I understand it you're expanding the molecular structure with the heat, and trapping tiny particles of dye in between the molecules when it cools down. This is something I was told once, and haven't been able to find an independent confirmation on, so that take with a grain of salt. Whether that's the case or not, the temperature aspect is -still- critical. Perhaps dye is the wrong route with CAB. How about a can of Montana brand spray paint, or appliance epoxy?
I can't believe how comprehensive SAK-wielders are, but because of that I can tell you that the warping temperature is at least 70°C / 158°F, as per The Dishwasher Test. https://www.swissarmyknights.com/articles/2009/april-2009/426-urban-sak-myth
comis, Unfortunately, it's not a case of "will not work as well as" but a case of "will not work at all." If you acid dye acetate, when you remove it from the bath and rinse it off, any and all color will run off. It simply will not stick at all. This is besides the fact that both methods will demand temperatures beyond what the scales can handle without damage. If you have a transparent scale, taking it off and painting it from the inside sounds like a great option for changing the color and avoiding chipped paint. I personally would just take the scales off and hit them with a coat of high-quality primer and then a high-quality spray paint, but I know a lot more about dye than I do about paint. Sorry for the bad news, hope this helps some anyway.
Some great info here, thanks for posting WHF Do you think Kool Aid would dye jigged bone ?
Greetings SteveC...Never tried dyeing bone, but bone is mostly collagen if I am not mistaken. I believe collagen is a polyamide and Kool Aid when used as a dye, or other acid dyes, should adhere well to all polyamides to the best of my knowledge. I'd bet money that you can dye bone with Kool Aid. Please let us know your results if you do try! Hope this helps.WHF
I've seen folks use Kool aid to dye jigged bone with excellent results. I used To to dye a red bone Stockman to a brown, which I much prefer.
