I have been wanting to add a couple of tools (awl and eye-glass sd) from a Wenger Pocket Tool Chest to my custom Minichamp for a while now... Finally have the materials and the time to realize this dream...
To start of, this is my Custom Minichamp which I had built a long while back... It has the flat sd combo tool added...
Next, is dismantling the Pocket Tool Chest. The pins are 2mm in diameter.. Has a solid head on one side and a bushing (similar to Victorinox) on the other end... I simply drilled the pins on the bushing end...
Upon inspection, the 65mm tools are longer... It will have to be shortened to the length of a 58mm tool (I used a main blade I had lying in my parts box as reference), relocate the pivot hole and reshape the pivot to closely match the 58mm blade pivot...
I initially determined the new pivot hole location and drilled both tools using a 1.6mm drill bit... This is to allow cutting and reshaping of pivots a little easier...
Next was dismantling my custom minichamp and reassembling everything.
And here is the result... Now my Jedi Mini Tool Chest is complete...
Additionally, I reassembled all the remaining parts from the PTC rather than leave it lying around idle...
I hope this guide can be of help to others wanting to do the same...
