New for 2020 - PowerAccess Assist MT 3129
Full Member Posts: 124
gav
Re: New for 2020 - PowerAccess Assist MT
« Reply #30 on: April 02, 2021, 09:01:53 PM »
That gap houses the spring for the four outer blades.
Full Member Posts: 245
« Reply #31 on: April 04, 2021, 02:23:42 AM »
Ok, I can see the springs at the thumb stud cutout and at the slots on the inside when the blade is open.
I just saw a YouTube vid of it cutting some nails in two.  No damage to the wire cutter jaws.  Did they harden the cutters?
SOG needs to do something similar to the Leatherman OHT and put symbols indicating which tool is where by putting an imprint of the implement on the scales/handles.
There seems to be some unused real estate toward the front of the tool.  Maybe tuck a small SAK tweezer or eyeglass flat blade driver (separate implements) into the spring slot?
This MT has too many flat blade drivers (4) and no scissors.  Can the micro flat blade be removed and replaced with a small scissors from another SOG MT?  Is there an across-the-MT lineup compatibility?
Also would love to see this tool in gold Ti/Ni.
« Last Edit: April 04, 2021, 02:49:55 AM by carl »
Total Receipts: $79.60
PayPal Fees: $5.65
Net Balance: $73.95
Below Goal: $226.05
25%
Page created in 0.036 seconds with 33 queries.
© 2018 Defender Web & Tool
