Recommendation for reliable high drain 18650 and 18350 311
Absolutely No Life Club Posts: 8,688
« on: February 02, 2020, 11:06:54 AM »
Hi, all.
Just want to get some recommendation for good reputable/reliable 18650/18350 for high drain/amperage usage(about 8A and 6A continuous respectively).  I've been out of the flashlight scene for a long while, and the landscape has changed drastically over the years.  Ideally I would love to find something protected, but reliable unprotected are also welcomed!
Join Daredevil Challenge in August and get Free magnets!
Comis Gear Youtube Channel
No Life Club Posts: 3,307 One Day Closer To Death
Re: Recommendation for reliable high drain 18650 and 18350
« Reply #1 on: February 02, 2020, 11:33:00 AM »
Samsung 30Q's are good, a lot of BLF community use, I don't have any 18350 lights, but I got these awhile back for FW3A light:
https://www.illumn.com/batteries-chargers-and-powerpax-carriers/18650-samsung-3000mah-inr18650-30q-high-discharge-flat-top.html
These are flat tops, the have button tops too. If you are getting a light that requires high drain cells may need to stick with unprotected, but I'm not 100% sure, I think a lot of these lights may trip protection circuit on turbo. Check manufacturers specs for max battery length light can handle and if you can/need to use prot/unprotected
« Last Edit: February 02, 2020, 11:38:27 AM by Blackbeard »
BB :B:
Full Member Posts: 185
« Reply #2 on: February 02, 2020, 04:02:46 PM »
LG INR 18650 HG2 3000 mA - 20A
Samsung INR 18650 30Q 3000 mA (15 A)
Sony Murata VTC6 3000 mA (30A)
If you think 10 A is enough, look also Sanyo NCR 18650 GA 3350 mA (10A) or LG INR 18650 MH1 3200mA  (10A)
if you are looking for protected batteries I have had good experiences with KeepPower, it produces 10 A and 15 A protected batteries
I buy batteries from a Dutch seller but I know it also fast ships to the USA
« Reply #3 on: February 02, 2020, 05:44:13 PM »
Thank you!  I looked it up, and it does seem to be a pretty good well-rounder, awesome!
« Reply #4 on: February 02, 2020, 05:46:50 PM »
I too read about VTC6, just not sure what kind of battery it is? Is It IMR or INR?  Btw, I've been away from the scene long enough to not know the exact difference.  Is INR more stable/safer than IMR?  I think it packs more capacity, but just not sure whether there is safety improvement.
The protected cells are indeed very interesting, I gonna ask my flashlight maker to see whether that's compatible.
Zombie Apprentice Posts: 15,033 Yoo-hoo, big summer blowout!
« Reply #5 on: February 02, 2020, 06:01:49 PM »
IMR is a high drain and pretty safe chemistry. Not as high capacity as ICR, but safer.
INR is IMR, but with Nickel added. All the advantages of IMR, but slightly safer and slightly more capacity.
Safety:
INR > IMR > ICR
Capacity (I think):
ICR > INR > IMR
« Reply #6 on: February 02, 2020, 08:16:28 PM »
What flashlights are you planning on using these batteries?
« Reply #7 on: February 02, 2020, 08:36:01 PM »
I am in processing of acquiring an Oveready Boss, but the batteries might be applied elsewhere which high amperage might be needed.
« Reply #8 on: February 02, 2020, 08:54:40 PM »
Normally 10A is enough for most applications but if you want to be safe go to Samsung 30Q
They are excellent batteries (see HKJ review)
https://lygte-info.dk/review/batteries2012/Samsung%20INR18650-30Q%203000mAh%20%28Pink%29%20UK.html
"Conclusion
This cell is very good, it can handle about 15A continuous discharge and has no problems with 20A pulses."
Total Receipts: $168.70
PayPal Fees: $9.84
Net Balance: $158.86
Below Goal: $141.14
53%
Page created in 0.205 seconds with 38 queries.
© 2018 Defender Web & Tool
