I wish the Rebar had an option for a clip or came with one from the factory. The size is near perfect for pocket carry.
You are right about the Spirit, it does not have an option for a pocket clip. If I remember correct, someone glued a nite-ize removable clip (or similar) to it and it worked fine. Maybe that would be an option for you
Nite Ize clip actual comes with double sided tape that sticks real well but then comes off clean if you decide you don’t like it. I used one on the Rebar for a while and it also fit the Spirit.
Is that the HipClip one? The one they sell for mobile devices?
https://www.amazon.com/Nite-Ize-HipClip-Attachable-Smartphones/dp/B007CBSBM4
