....the tools are too small, they take forever to get out because of those flaps, the lock lets go easily and the tools stick together when you try to take one out.Its a good set of pliers but thats about itA99S
I got rid of the Tough Tool because it was so difficult to move the individual tools, even after lubing them, and there was no way to fix it.
Bumping an really old but interesting thread. Now we know what exactly cap crimper does, how about C4 punch?
Okay then here's a question:Has anyone here actually used a blasting cap crimper for its intended purpose?
Also want to ask you about your power lock, does putting v-cutter next to combo blade make the plier hard to close or is there plenty of space?
And worse, to release the lock if you accidentally lock both locking tools open while trying to disengage them! At least when LM used a similar type of lock on the original Super Tool they made it so all the tools could disengage the lock, so you had a greater margin for error.Of course, that's probably why LM id that with the Super Tool.Def
Quote from: Defender on September 10, 2006, 02:02:23 PMAnd worse, to release the lock if you accidentally lock both locking tools open while trying to disengage them! At least when LM used a similar type of lock on the original Super Tool they made it so all the tools could disengage the lock, so you had a greater margin for error.Of course, that's probably why LM id that with the Super Tool.DefThats not how your supposed to release the tools on both sides of the Tough Tool there are tools that are release levers the orange pealer and the scraper blade if you push down on them it unlocks the locked tool(s).
