You guys are slacking ...KNIFE WRENCH !!!!! (Image removed from quote.)Practical and safe
Just because you can make it, doesn't mean you should.... Honestly, I just don't see the point in something like this. Too awkward to use as a knife; and due to the knife, the wrench part is a little compromised. And besides, if I'm dragging out the wrench I have this size; it's either a big bolt/nut, or something's stuck pretty good. And besides, I don't think I have a pants pocket that would fit this thing. At 24" I'd question it even fitting in my pack.
I really like it, not $143 like it but like it all the same, so much so i decided to go out and make one for myself, with a difference.... mine is a fixed blade it's great, you can peel an apple then undo a bolt, then slice a pizza and straight away go and tighten that bolt, fantastic idea Just be sure to wear thick gauntlets, oh and don't try to use it in the dark..(Image removed from quote.)
Ok, no molle straps. I still would like two of those tools stuck together at 90 degrees so I can cut and screw in different directions at once.
That's definitely a normal sized mt with a 3 year old holding it.
