Login
Register
Menu
Home
Help
Forum
Tool Talk
Leatherman Tools
My wife broke my Charge TTi!
kkokkolis
22 ·
1575
« previous
next »
Print
Pages:
1
Go Down
kkokkolis
Absolutely No Life Club
6,350
Τετραφάρμακος
on:
October 05, 2019, 12:53:10 PM
Yes, she did it, trying to remove a screw from a marble floor (a door stop remnant). Thankfully she broke it at the tip. She offered to buy another one, but I wasn't fond of the thin tip anyway, so I consider shortening the other tip to come flush with the broken.
My question is: is a dremel powerful enough to do the job (and with which accessory) or bother not and go to a professional with a stone wheel?
Στάλθηκε από το MAR-LX1A μου χρησιμοποιώντας Tapatalk
Penny Folders
My SAKs & MTs
My EDC & SDC
Merit Badges
microbe
No Life Club
2,307
Yersinia Pestis & Campylobacter Jejuni!
Re: My wife broke my Charge TTi!
Reply #1 on:
October 05, 2019, 01:06:19 PM
How about sending it in for warranty? You may get a new one.
If warranty shipping and wait time is to much for you, and as it looks repairable to me, I'd take it to a metal shop and have it grinded even.
@blackdiamonds_42
Merit Badges
Fuzzbucket
9,585
Reply #2 on:
October 05, 2019, 01:08:35 PM
It's doable with a Dremel type tool, but I'll be a pain and the end result might be a bit messy. You'd be better off and will get more professional results with a grinder or belt sander, but remember to quench frequently. It's not too bad a break really.
Merit Badges
Fuzzbucket
9,585
Reply #3 on:
October 05, 2019, 01:10:00 PM
... and what microbey said.
Merit Badges
kkokkolis
6,350
Τετραφάρμακος
Reply #4 on:
October 05, 2019, 01:16:26 PM
Thanks. Can you define quenching please?
Penny Folders
My SAKs & MTs
My EDC & SDC
Merit Badges
lister
No Life Club
1,480
Reply #5 on:
October 05, 2019, 01:25:14 PM
Quote from: kkokkolis on October 05, 2019, 01:16:26 PM
Put in to a liquid to cool of and lock in the desired structure of the steel. But what you want to do is to use water to cool it off before any unwanted changes happen due to heat buildup. I go by the rule if it is too hot to hold it goes in to the water. That means dunking it multiple times in a minute.
And dremel should have not trouble taking off that remaining tip. I use the thing that look like a roll made out of sand paper that you put on to a rubber insert for the dremel. Don't know what it is called...
Merit Badges
Rapidray
Absolute Zombie Club
24,490
Reply #6 on:
October 05, 2019, 03:00:10 PM
you will be ok
Merit Badges
Aloha
Global Moderator
Point Of No Return
31,235
Reply #7 on:
October 05, 2019, 03:44:43 PM
I have used a cut off disc ( very flat disc ) then the sanding drum ( described above ) to smooth things out afterwards. MULTIPLE dunks in water ( room temp water ) to keep the metal from over heating. Like said above if the metal gets to hot to touch it goes in the water. Its actually a fast mod to do. You can use a file to do any touch ups afterward.
Use safety glasses and gloves and hold plier in a vise. Be safe and go for it and good luck.
Here's my mod I did.
https://forum.multitool.org/index.php/topic,64572.msg1224537.html#_
Merit Badges
kkokkolis
6,350
Τετραφάρμακος
Reply #8 on:
October 05, 2019, 08:57:57 PM
Thank you very much
Penny Folders
My SAKs & MTs
My EDC & SDC
Merit Badges
Poncho65
Global Moderator
Just Bananas
86,013
Reply #9 on:
October 05, 2019, 09:28:59 PM
but it isn't hard to fix
I had had to do this one 1 or 2 before
Great info above so I won't repeat it
and good luck
Merit Badges
kkokkolis
6,350
Τετραφάρμακος
Reply #10 on:
October 06, 2019, 02:02:22 PM
Twice unlucky. I used my Dremel clone to cut it. It was cut easily. But immediately afterwards the damned thing stopped working and I wasn't able to finish it. I might have to buy a genuine Dremel now and finish the job.
You can see that the tool isn't pretty at the OCD level (the tips come flush, but one is broken at an angle, the other cut) but it is fully usable, which gives me time to buy the tool.
Now the question is: Which Dremel, 3000, Stylus, another one?
Penny Folders
My SAKs & MTs
My EDC & SDC
Merit Badges
Aloha
Global Moderator
Point Of No Return
31,235
Reply #11 on:
October 06, 2019, 03:54:07 PM
You can file at this point to smooth things out if a usable tool is wanted. If you want more OCD level tool you'll have to take more off both to level them out. Another option after the work is done and IF you are not happy is LOKI. You can buy a plier head from him for far less than a new TTi.
As far as which Dremil, I have an older one so I'm not up to date on them. I'll have a look at what I have.
Last Edit: October 06, 2019, 04:04:50 PM by Aloha
Merit Badges
Juan el Boricua
No Life Club
3,141
Reply #12 on:
October 06, 2019, 03:58:05 PM
Excellent job, kkokkolis! Maybe you can radius the cuts using a file, and finish off with sandpaper?
About the Dremel, from the list of choices, I'd get the 3000. But, if I were going to use it only for basic cuts, deburring, sanding, and general polishing I'd get a 2-speed 200 series; 15k and 30k speeds are enough. The advantage of the 3000 is that you can lower on revolutions, and be able to cut/polish plastics without melting.
Good luck on your endeavour, and enjoy your "new tool"!
Merit Badges
Poncho65
Global Moderator
Just Bananas
86,013
Reply #13 on:
October 08, 2019, 11:39:14 AM
Well you are almost there
To bad the Dremel clone quit on you though
I would go with a variable speed one for sure
if the 3000 is that, then that is what I would get
A regular file would finish this job though and a diamond file would make it asthetically pleasing looking
Merit Badges
Rapidray
24,490
Reply #14 on:
October 08, 2019, 04:15:03 PM
Merit Badges
Aloha
Global Moderator
Point Of No Return
31,235
Reply #15 on:
October 08, 2019, 04:17:33 PM
Totally forgot sandpaper at this point
( Juan ). Hard part is over ( cutting ) just take your time and smooth out everything.
Merit Badges
kkokkolis
6,350
Τετραφάρμακος
Reply #16 on:
March 01, 2020, 03:14:46 PM
I just bought a tool yesterday and now it's even.
Penny Folders
My SAKs & MTs
My EDC & SDC
Merit Badges
Aloha
Global Moderator
Point Of No Return
31,235
Reply #17 on:
March 01, 2020, 03:23:36 PM
Good to see you. Glad you finally got it sorted out. With the right tools it a straight forward task. Now you've got a tool and who knows what else you'll want to do
Merit Badges
SteveC
Global Moderator
Just Bananas
67,620
Reply #18 on:
March 01, 2020, 04:10:00 PM
Merit Badges
Mechanickal
Zombie Apprentice
14,686
Reply #19 on:
March 01, 2020, 04:14:33 PM
I'm also reassured to hear from you again...
Merit Badges
Poncho65
Global Moderator
Just Bananas
86,013
Reply #20 on:
March 02, 2020, 12:12:16 AM
great to see you, buddy
Merit Badges
Juan el Boricua
No Life Club
3,141
Reply #21 on:
March 02, 2020, 12:48:44 AM
Excellent job, kkokkolis! Loving the radiused tip.
Enjoy now both of your new tools!, and keep us informed.
Merit Badges
Print
Pages:
1
Go Up
Forum
Tool Talk
Leatherman Tools
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$152.99
PayPal Fees:
$8.68
Net Balance:
$144.31
Below Goal:
$155.69
Site Currency:
USD
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
