Polishing it won't help either.
I agree, but with my first P2 they just canged for one in the same condition.<snip>I don't think Leatherman is giving the attention or level of importance to this issue.
This is very disappointing. LMs response is to send a new tool out under warranty . They should also be paying for you to do that as well since its clearly a issue on their part. What's so darn funny is how much they belittled the other offerings ( well that one tattooed guy did ) when announcing this stool ( no typo ). When I see the grey sheath I'll know the pliers bind up, while my tool in the black sheath performs wonderfully.
Well...after 3 days of on-and-off ‘exercise’, including pressing some automotive abrasive into the pivot, I get beautiful free swinging pliers...until I squeeze them, and they bind up again. There’s clearly an engineering geometry issue at play here. Not something I’m going to be able to fix, so it’s going back the shop. They can send it in for warranty. Hopefully I don’t get it back whacked, but I get one that works. Have done a video here showing that I need over 500g of pressure to close the pliers when they bind, and that after a wiggle, they are free again. Not acceptable Leatherman.
No smurf, this sucks!I had mine right in front me on the table, and just can't help but to give it a firm hand-shake squeeze, and guess what--I just joined the club and now it won't move freely. Can't imagine what's gonna happen if I give it a real squeeze or need it to cut something.I gave my old Charge the same squeeze, it binds a little bit but I guessed I have used it enough it frees right up after moving the handles couple of times.(or maybe the handle is heavier?) Gave many times harder a squeeze to Victorinox Spirit and Swisstool, until the handles bow inward, no binding whatsoever.I once said somewhere that this tool is not well thought thru, and only focusing on the aesthetic or appearance, I hate to be right on this. Even cheaper tools from 20+ years ago can do better.
True locking tapers are typically a lot less than the 30o shown, but over the years I have found that stuff can have a nasty habit of jamming up when you don't want it to, at or around 30o. I've had it with cutting tools (taper drills and bore forming tools), taper gibs, self aligning bushings etc. A real pain in the well padded area!If the void is drilled with an indexable insert U drill, there's a good chance that the face transition is less than 30o anyway. If they use an indexable insert stepped drill, which would be the most efficient way to drill out the castings, it's likely to have a TPMT insert for the counterbore, set around 15 to 18 degrees. That would fit these symptoms perfectly. That's what happens when you gear your production facilities around production efficiency, rather than what the component actually needs. Seen it far too often.
