Login
Register
Menu
Home
Help
Forum
Tool Talk
Edged Tools
Chisel grind?
Chisel grind?
Benner
11 ·
5325
« previous
next »
Print
Pages:
1
Go Down
Benner
Global Tuffy
Absolute Zombie Club
28,081
Just Awesome! And a Slayer of Polar Bear!
Chisel grind?
on:
January 01, 2009, 07:37:42 PM
It has been mentioned recently that people dislike chisel ground blades and I was curious to know what the general thought was on this grind on a pocket knife?
When looking at folders recently, I was surprised to see that one brand of knives that I was interested in, Emerson
http://www.emersonknives.com/
, mainly (could even be all of them) does chisel ground edges on their knives. This immediately put me off but I don't really know why
So what do you guys think?
Mike, Lord of the Spammers!
Chief of the Absolutely No Life Club!
Abandon All Hope Ye Who Enter Here...
42,975
Why haven't you got a Farmer yet!
Re: Chisel grind?
Reply #1 on:
January 01, 2009, 09:44:28 PM
A true chisel grind is a hell of a lot weaker than a conventional V grind, as it's only got half the steel suporting the edge
The only pluses are it's cheaper for the manufactures
, and easier to sharpen in theory, but I would steer well clear of them if I were you
Leatherman123
6,568
Re: Chisel grind?
Reply #2 on:
January 01, 2009, 09:47:31 PM
I am not a fan of chisel ground blades either.. They get scary sharp, but they are pretty hard to sharpen and like Mike said; are weaker..
B
Flash
Guest
Re: Chisel grind?
Reply #3 on:
January 01, 2009, 09:51:07 PM
Benner...one benefit is that they are great for really detailed carving/precision work.
I think the CRKT Edgie is of a similar grind and that works for me great.
Different grinds for different jobs...as Scotty used to say "the right tool for the right job"
Leatherman123
6,568
Re: Chisel grind?
Reply #4 on:
January 01, 2009, 09:52:15 PM
The Edgie is a fantastic knife! It's good for the UK members because it doesn't lock!
B
hawkchucker
No Life Club
4,783
I miss Benner
Re: Chisel grind?
Reply #5 on:
January 01, 2009, 09:55:59 PM
The main problem witht he grind is also trying to keep the cut straight in wood. It tends to track out.
Plus I just find it lazy that manufactures use it.
S
Leatherman123
6,568
Re: Chisel grind?
Reply #6 on:
January 01, 2009, 10:09:18 PM
I am fond of chisel ground serrated blades, though!
B
hawkchucker
No Life Club
4,783
I miss Benner
Re: Chisel grind?
Reply #7 on:
January 01, 2009, 10:16:49 PM
But they work with serrations. Just not in solid stuff.
S
Nutznboltz
Sr. Member
339
Re: Chisel grind?
Reply #8 on:
January 03, 2009, 12:21:45 AM
Chisel ground blades are razor sharp, that's the only advantage for users. For the manufacturer they're cheaper to make and where a combination blade is offered, more often than not you'll find a chisel grind as the serrations would be chisel ground as well.
Personally I don't mind this type of grind, though sharp it's more fragile than a conventional v grind and prone to nicks.
The only way I've found to re-sharpen them is on a stone or Lansky system where you have to regrind the edge completely. It's more work but you'll end up with a razor sharp blade. Its virtually imposible to touch up a chisel ground on a sharpening steel or "v" sharpener, at least that's what I've found.
David
8,826
Re: Chisel grind?
Reply #9 on:
January 03, 2009, 07:28:29 AM
I`ve got chisel grinds on Victorinox Gardner, LM Micra, Perrin La Shark and a whole bunch of Emersons both custom and production. The grinds on the Emersons I have range from zero ground, chisel ground and the v-grind which is only sharpened on one side. Emerson is my favorite brand of knife and there been hardly a day gone by in the last 10 years that I`ve not carried one or had one availible for use if needed. I do use some other knives from time to time but Emerson is by far my favorite. There not for everyone people tend to love`um or hate`um. I`ve never found a chisel ground blade that I`ve used to be weak or hard to sharpen. Altho a zero ground blade if not done right or tempered correctly can be fragile. They did take alittle getting use to in the beginning. The Emerson Commander was a real challenge to learn how the sharpen that recurve chisel type blade but once I figured it out its very easy to sharpen, for me any way. My brother has watched me sharpen his Commander for along time now and still cant do it. I use one crock stick. I`ve never reprofiled any of blades as many now days do. Is there any real advantage for the average knife user proablity not. I`m not a big promoter of the chisel ground blade I just like Emersons and have learned how the use them.
Merit Badges
Splat
Hero Member
906
Re: Chisel grind?
Reply #10 on:
January 08, 2009, 02:32:55 AM
I've found I don't like chisel grinds. They tend to pull to the side when cutting. I prefer flat and convex grinds.
Splat
Print
Pages:
1
Go Up
Forum
Tool Talk
Edged Tools
Chisel grind?
January Goal:
$300.00
Due Date:
Jan 31
Total Receipts:
$62.07
PayPal Fees:
$3.62
Net Balance:
$58.45
Below Goal:
$241.55
Site Currency:
USD
19%
January Donations
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
